Thank you for this review! I have been interested in these two lenses for a while. The compact size of the Pentax is enough to justify the extra cost to me. I appreciate you going over the details to help me understand it.
As a technically-minded person, and generally a critical thinker I have a few questions and suggestions for the review. I hope you don't mind? I certainly don't mean to be negative or anything.
In discussing the bokeh of the two lenses, the following paragraph is rather confusing:
Quote: As can be seen in the test shots provided at the end of this review, the two lenses perform quite similarly in most cases. In only one occurrence did the Tamron deliver a surprisingly dynamic bokeh. The following image illustrates the phenomenon, which occurred when a background with strong textures was photographed with the lens wide open. It was never observed in other situations, so it is a marginal issue.
What does "deliver a surprisingly dynamic bokeh" mean? That sentence alone seems to indicate, based on the way I am accustomed to speaking and reading about bokeh, that in only one image did the Tamron's bokeh actually impress. ("Dynamic" almost always bears a positive connotation as well.) But if that is the meaning then it is in direct contradiction to the first sentence in the paragraph, and to the entire preceding paragraph, and to the final bokeh rating the lens received in the review. Further, the image that follows is of a bird, but it's several sections later in the review. But it seems that it could match what is being described, in that there is an obvious difference between the subject and the background, but nothing about the background/bokeh that I would describe as "dynamic". At any rate this section is not clear.
Also (and this I suspect has more to do with the site design than the specific review), the side-by-side bokeh examples are almost impossible to gauge because the viewing windows are so small. Personally I got around this by opening the respective images in separate tabs. (Thank you for naming the files after the respective lenses! SO much easier to keep them straight that way.)
A few little nit-picks as well:
* The Tamron sample photos are predominately distant subjects. The Pentax sample photos are predominately close-up (more typical use for a macro lens) subjects.
* At least on my screen the Tamron samples are almost always sharper than the Pentax of the same subject. ("Pentax Sample 2" and "Tamron Sample 2" seem particularly dramatic examples. But it also looks like the Pentax could just be focused a little deeper in that shot?)
* The Tamron section begins by stating that this is the most up-to-date version of the lens. But I can't find a date anywhere on the page or within the review (except the mention of the expiration of the available Tamron rebate) to document when this was written. Right now that is easy to figure out, but in theory this review will be up for a while. Might want to add that for posterity.
* Finally (and this is, I think, is more of a site design matter than specific to this review), in the dropdown navigation menu there is a link to "discuss this review". It does not, however, lead to a discussion of this review as we are having in this thread. That was found by noticing it in a list of recent forum posts, after being frustrated that following the above link actually goes to a page where users can submit their own reviews for 3rd party lenses (why default to 3rd party when this review included the Pentax?). Again, a small matter but from a usability standpoint it's kind of frustrating. Changing the wording of the link to "add your own review" or "see other users reviews" would make a lot more sense.
