02-24-2012, 03:30 PM   #1
RickyFromVegas's Avatar
MC ( Multi Coat) and its benefits?
Hello. I was just wondering about MC and its benefits on the lens.
I assumed that MC helps to resist flare and bunch, but never sought out for clarifications on that.
Another question is if an existing lens without MC treatment were to have multicoated uv filter on it, would it act as if the lens has a mc treatment?
or is that just wishful thinking?
02-24-2012, 03:32 PM   #2
alohadave's Avatar
QuoteOriginally posted by RickyFromVegas Quote
Wishful thinking.
02-24-2012, 04:12 PM   #3
Lenses are either uncoated, single coated or multi coated. Glass reflects light. Not only will some of the light not enter the lens as it is reflected away, but every glass surface inside the lens will reflect light that will go bouncing around inside the lens. The inside of the lens is generally painted matte black to try and absorb as much as possible of this stray light. A single coated lens is the proper thickness to eliminate reflection of one wavelength of light only (one color of light only). If I understand right, the further you get from that wavelength, the more that color is reflected. They would therefor typically use a single coat tuned in the middle of the visible spectrum of light to get the most benefit. Light near the middle of the color range would get reflected the least and colors near the ends of the spectrum would get reflected the most. Multi coating uses different thickness coating that are tuned to different wavelengths, decreasing the amount of light reflected more.
If you use a multi coat filter on a lens, it may stop some reflection on the front of the lens, letting a little more light into the lens, but once in the lens (or even off the uncoated front element), the light will still get reflected off every glass element it hits.
I would imagine that the cost of disassembling a lens, cleaning and preparing the glass, and doing a custom coat job would cost much more than a new lens, if there is even any one that would do that on a single lens basis.
Edit: Seems I was wrong. You can get lenses coated. I found one reference of someone getting the glass coated in a Rolleiflex 3.5F coated which seems to have 5 or 6 small elements x 2. They stated 350$ for that. That was only for duplicating original coating on that camera though. Another mentioned 50 pounds per surface (GBP I assume?) so maybe 80$ US per surface?
A simple prime lens might have 6-10 elements (maybe more), a vivitar series 1 70-210mm has 14-15 elements (just a guess at what the average zoom has).
Figure 500$ to over 1000$ plus cost of shipping both ways to another country?
You might be able to find something cheaper, but regardless, it is obviously only economical for very expensive lenses. I think it is generally intended as an option for repair of very expensive lenses (where you might not have to do all surfaces I guess).
02-24-2012, 04:25 PM   #4
All modern lenses have MC just about, but if it's an old lens (i.e. a Takumar), it might just have a single coating or no coating at all. Newer coatings are also more effective than older ones, it seems.
02-24-2012, 04:30 PM   #5
The reason why I'm asking is because I have Helios 44-2 58mm.
The thing is not coated, so when shooting towards the light source, even a little bit, reflections take over a large part of the image. Was wondering if there is any way to remedy this problem a bit.
Example: one of the worst case of flare I've experienced.
The later versions of this have MC, but loses 2 blades (older has 8 blades, newer ones have 6) in the process and the bokeh looks different and more tamed, which I don't like as much.
02-24-2012, 04:35 PM   #6
Laurentiu Cristofor's Avatar
The main benefit of coatings is in increasing light transmission. A filter won't do any good with that. Coatings were discovered in the 30s independently in Germany and USA - read the article on wikipedia for some very interesting information. Coatings that protect against flare or ghosting were developed later - filters don't help with that either - the best they can do is to avoid introducing flare and ghosting themselves.
From a photographic perspective, however, uncoated or single coated lenses can have different rendering characteristics and might be desirable because of that. Helios 44 lenses, for example, have gained sharpness as they gained multicoatings, but their bokeh is allegedly different.
02-24-2012, 04:38 PM   #7
rparmar's Avatar
Adding a filter adds a new gas layer and a new glass layer, neither of which were taken into account by the lens designer. This provides more surfaces for spurious reflections, scratches, dust, etc. and more possibilities of degradation.
I never use filters for "protection". Use a lens hood instead.
If you have a lens without MC that is subject to flare, shoot in situations that avoid this problem. Or get a longer hood. Or use your hand for shade. As a photographer, you can outwit your gear. ;-)
02-24-2012, 04:39 PM   #8
Yes, follow religiously Rule #1 of using Russian lenses: Don't shoot into the light! Keep the sun in the back!
I started photography with a Russian rangefinder and I still position myself with the back to the sun when I'm about to photograph something - I don't even think about it.
02-24-2012, 07:18 PM   #9
hcarvalhoalves's Avatar
I have the same lens, but probably a newer, multi-coated version. It doesn't flare that bad even shooting right into the sun:
IMGP2460 - Version 2 por hcarvalhoalves, no Flickr
02-24-2012, 07:26 PM - 1 Like   #10
BTW, here's an interesting video showing some pretty simple lenses being made. From 1:55 and on you can see their coating process.
02-25-2012, 02:56 AM - 1 Like   #11
simbon4o's Avatar
Тhere are coatings and coatings, try the M 50 1.7 against the sun there is no GDR glass that can match!
02-25-2012, 03:08 AM   #12
I have FA-A-M 50mm f1.4-f1.7-f2.
A50mm1.7 being my fav.
02-25-2012, 11:25 AM   #13
QuoteOriginally posted by hcarvalhoalves Quote
Ahhh! Multicoated windows!
02-25-2012, 02:14 PM   #14
kcobain1992's Avatar
The solution is called lens hood, and avoid shooting into the sun. Look for a 49mm diameter, and get the longest one you can get (for telephoto, doesn't matter, the longer the better).
k-mount, lens, mc, pentax lens, slr lens, treatment
Getting a K5 benefits my granddaughter! PALADIN85020 Pentax K-5 4 05-24-2011 04:32 AM
Matte of gloss coat? dj_saunter Digital Processing, Software, and Printing 9 03-11-2011 09:18 AM
For Sale - Sold: B+W 49mm UV HAZE Filter MRC 010M F-Pro Multi Coat (US) pcarfan Sold Items 0 12-14-2010 06:47 PM
WR - more than weather benefits? pacerr Pentax SLR Lens Discussion 4 12-03-2010 07:19 PM
Super Coat? NecroticSoldier Pentax SLR Lens Discussion 6 04-06-2010 04:46 PM
All times are GMT -7. The time now is 09:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
