For landscapes I find that f4 is more than sufficient - and even at night, my shutter speeds just extend (using a tripod). I have the 16-45 and find it to be a very good lens. I also have the 55-300 and it covers its range nicely supported by a 50mm/f1.7 and an 85mm/f2.8. Most of my shooting is wider than 50mm.
Most landscape photographers shot at 28-30mm, in that distortion is virtually non existent. Also, as you go wider, the center of the image is push into the background to make room for the additional field of view being pulled in along the edges. I tend to do quite a bit of stitching - in that solves most of these problems. I can go as wide as I want, without relegating the main subject of the frame in to the background. I also have gone for f4 glass since I really do not need fast. That said I have splurged on two primes (f2.8) from Contax (Carl Zeiss) the first one to see what the difference was and the second one since the first was so good and I found the 85 for a good price.
