02-26-2012, 11:45 PM   #1
sterretje's Avatar
Is M42 always M42 (registration distance question)
Till now, for me, M42 refers to the thread. Does it also 'define' the registration distance?
I have the opportunity to buy a wideangle Olympus M42 lens to basically complete my M42 kit. I wanted to buy it last month but ended up with some vet bills Want to pull the trigger now but realized last night that there is a possibility that the registration distance might be different. Better safe than sorry It will be used on a Pentax dSLR.
And is there anything else to pay attention to (e.g. rear element protruding into camera)? It's my understanding (from research on the web) that it works on a 5D Mk II without mirror issues.
Thanks in advance.
02-27-2012, 12:33 AM   #2
Philoslothical's Avatar
I'm no expert on this, but as far as I know, an m42 is an m42, they're all the same with regards to register. I've never heard of one that has a different register. Don't take my word on it alone, if you're worried. I'm sure others will chime in on this.
02-27-2012, 03:25 AM   #3
sterretje's Avatar
OK, I think I found the answer to the first question in wikipedia: M42 lens mount - Wikipedia, the free encyclopedia . The registration distance is defined in the specification.
So now the answer to the second one (if possible).
02-27-2012, 05:31 AM   #4
Stone G.'s Avatar
The M42 X 1mm mount is indeed a universal mounting standard and the registration distance should always be 45.46 mm.
You may read more here:
02-27-2012, 06:39 AM   #5
eddie1960's Avatar
Some of the Olympus m42 have an additional pin on them as well that might be a small issue (from Camerapedia)
Olympus Edit
Olympus made a small range of lenses in M42 mount, for their FTL body. There is a rumor saying that these lenses were not designed nor built by Olympus, and that they had nothing to see with the later OM lenses. However their characteristics are very similar to the equivalent OM lenses.
28/3.5
35/2.8
50/1.4
50/1.8
135/3.5
200/4
These lenses have an additional pin to lock them into place on the FTL body. On some other M42 bodies, this pin could prevent from mounting them.
02-27-2012, 08:49 AM   #6
drougge's Avatar
As others are saying, M42 is a standard mount, including the registration distance. There are however several other mounts using a 42mm thread that are not M42, but might be sold as such because the seller doesn't know. I don't think this lens is such a case though.
The only one you're likely to accidentally buy is probably T2, which has a 55mm registration distance and adapters to just about anything are readily available. T2 also uses a different thread pitch than M42, it won't mount smoothly in your adapter. Don't force it or you'll probably damage at least one of the adapter or lens.
(I also have two lenses using a T2 compatible thread but slightly longer registration distance, possibly using a system called Unidapter. They work well enough with T2 adapters, focusing a bit past infinity.)
Regarding the mirror, I don't think any M42 lenses have a problem on APS-C, but some do on full frame cameras with large mirrors. (The Kilfit Makro Kilar 40mm springs to mind.)
02-27-2012, 09:30 AM   #7
sterretje's Avatar
Thanks for the replies. I'm quite sure that the seller knows what he's selling (auto.zuiko 28/3.5, the first one that eddie1960 has in the list above) and I will meet him in person and take my camera with.
In this case I don't mind doing a bit of surgery if necessary with regards to 'the pin'.
02-28-2012, 02:21 PM   #8
QuoteOriginally posted by drougge Quote
The mirror clearance issue was an ongoing concern back-in-the-day and was often part of a lens review if clearance was a problem with certain bodies.
distance, k-mount, m42, pentax lens, registration, slr lens
For Sale - Sold: Zenit 17-69mm F1.9, 50/2.8, 135/2.8s, 180/3.5, 200/3.5, 80-200/4.5, M42 adapter MightyMike Sold Items 128 10-11-2012 07:47 AM
For Sale - Sold: M42 Super Taks 50/1.4, 135.3.5, Auto Chinon 28/2.8, M42 adapter,Sun 2x tele converter olivemike Sold Items 3 12-18-2011 04:18 PM
Camera mount for Pentax M42 Auto Bellows? (NOT about M42-K adapter) baj Pentax Camera and Field Accessories 9 10-24-2011 10:42 PM
For Sale - Sold: m42 Tele-Takumar 300mm F6.3 and GENUINE Pentax m42-to-K adapter (US/CAN) LowVoltage Sold Items 5 03-22-2011 05:55 PM
M42 Tak registration distance on a K20D jbinpg Pentax DSLR Discussion 3 07-08-2010 04:08 PM
All times are GMT -7. The time now is 02:37 PM. | See also: NikonForums.com, part of our network of photo forums!
