02-28-2012, 02:46 AM   #1
Question on lens converters Nikon to Pentax
Hello,
could anybody tell me please if using a Nikon to Pentax lens converter preserves the AF capability of the Nikon lens.
I have searched the forum but found no answer.
Thanks a lot.
02-28-2012, 03:19 AM   #2
any sort of lens converter aside from the specially designed alpha-to-NEX converter will NOT preserve AF functionality
02-28-2012, 03:29 AM   #3
Thank you adpo.
02-28-2012, 03:33 AM   #4
Frogfish's Avatar
There is no standard way to fit an adapter to a Nikon cameras allowing the use of Pentax lenses. The registration distance of Nikon lenses is larger than that of Pentax lenses so they can not be made to fit without some destructive engineering work .. and often still not. Canon has a much smaller registration distance so there are many adapters allowing different brand lenses to be used on their cameras, including Pentax.
02-28-2012, 04:55 AM   #5
WPRESTO's Avatar
FYI:
Some years ago I used a Nikon to Pentax adapter to fit a Nikon 500 f4P to my Pentax LX. The adapter was actually a 1.4X teleconverter with a female Nikon bayonet on the front and a Pentax male bayonet on the back. The adapter was 100% manual - no aperture link so the Nikon tele has to be stopped down manually. The 1.4 lens system was very simple, causing substantial deterioration of IQ. I did not find this device in any way satisfactory and eventually purchased a used Nikon FA to put on the lens. Even with a 2X nikon converter to get 1000 f8 the results were easily superior to images taken with the N-K adapter on my LX.
02-28-2012, 06:28 AM   #6
QuoteOriginally posted by Frogfish Quote
I understood the OP's question the other way,
asking about using a Nikon lens on a Pentax camera.
Although AF as such won't work, the "poor man's AF,"
focus trap or catch-in-focus, should be available,
as with any MF lens.
02-28-2012, 01:22 PM   #7
Lowell Goudge's Avatar
There is a Nikon to pentax converter on the market presently from china. It is effectively a 2 element TC with a 1.25 magnification factor there is quite a lot of color bleed at wide open conditions at least with a 50/1.8 but stopped down it is useable. Similar adaptors exist for all makes with different magnification. Ased upon the thickness of the individual adaptors. The. Anon for example is 1.45 x
k-mount, lens, nikon, pentax, pentax lens, question on lens, slr lens
Macro Question- Nikon T5 & Pentax A 18-250 Lens sentinel Photographic Technique 2 01-14-2012 08:03 PM
pentax tele-converters sany Pentax Camera and Field Accessories 9 06-08-2011 08:25 AM
Pentax Tele-Converters? soppy Pentax SLR Lens Discussion 9 03-03-2011 10:49 AM
Sigma telephoto lens converters. oddie1990 Pentax SLR Lens Discussion 17 05-30-2010 02:15 PM
Question regarding using converters with lenses stl09 Pentax SLR Lens Discussion 5 04-29-2009 01:05 PM
All times are GMT -7. The time now is 01:41 PM. | See also: NikonForums.com, part of our network of photo forums!
