Originally posted by Douglas_of_Sweden Personally I prefer the enhanced Ernostar 5:4 lens solution (rear element is a cemented doublet instead of a single lens) that all the different Takumar 135mm's from 1953-65 use. Both optically and in build quality.
The identity of this lens certainly would be less interesting without PF. When I searched ebay for images of the Super T, every one I looked at (until tired) was like this one:
Asahi Pentax 135mm f/3.5 Super Takumar M42 Lens 1747000 | eBay
If I understand you right, they ALL have "coarse knotted curls on the aperture ring". Mine has no f4 setting, but the aperture ring simply looks like a larger version of the much smaller ring that's closer to the threads. It has that side-of-a-coin type notching, but no raised and smooth sections at regular intervals like the 4:4's you describe - it's circumference doesn't vary at all.
Also, I'm not really sure what you mean by "parts number". The only # related to the lens model I can find is the SN, in this case 849844, which you may not mean. I further note that the Super T's pictured on ebay seem to have much higher SN's - in the millions - which may or may not mean anything.
If you haven't had enough of all this, I'd really like to know what you make of my lens, and of course more on how to visually identify the enhanced Ernostar 5:4 lens.
Much Thanks.
