01-06-2008, 04:15 AM   #1
Buutopia's Avatar
DA* 16-50mm owners Please advise
I'm looking into getting purchasing a DA* 16-50mm. I've been reading post on this forum and it seems as if you get very good results when you get a good instance of the lens and not so great when you get a bad copy. I also heard that the later samples have less of a problem. So here are my two questions. Is the back focusing issue fixed in the newer copies? and can the owners of this lens please post the first few numbers of the serial numbers of your copy and whether you think that it is a good copy or a bad copy? thanks.
01-06-2008, 04:47 AM   #2
roentarre's Avatar
As long as the lens is not decentred, the lens does pretty well. Nothing to do with serial numbers and it is probably to do with luck.
I guess my Buddha had protected me from getting the bad copies for last few purchases (Stephen tested this copy for me while I got it from him in the market place here)
I had posted numerous shots in post your photo section already.
Here are a few examples...
Check out my site for some of the sample shots here - altogether 56 images. Just pick Da* 16-50 in the drop down menu.
James Wei :: Photography
If you like the lens, go for it.
01-06-2008, 06:00 AM   #3
PePe's Avatar
It is not really clear to me what the linkage between these quality issues and production runs is. I bought mine in September, the serial number is 901XXXX, and it is definitely one of the good ones.
01-06-2008, 09:15 AM   #4
After all the alarming messages on the DA*16-50, I've taken a number of test shots with my 18-55, 16-50 and 18-250 this afternoon.
Subject: the brick wall of our house.
Distance 50cm, all lenses wide open (f3.5, f 2.8, f3.5, at 18mm, 16mm, 18mm, ISO 100)
I've looked at them 50 times over and my conclusion is:
There is no clear winner for me.
The DA* center sharpness is best (not stopped down to get equiv f 3.5!)
Tamron 18-250 comes in at close second.
Cornersharpness of the Tamron is the best.
The DA* is less than the Tamron, comparable with the kitlens.
However, it is comparing 16mm with 18mm and f2.8 with f3.5!
Barrel distorion of the DA* is less than the Tamron, also vignetting is somewhat less.
I cannot see a lot of difference in colourshifting in the corners between the lenses.
Overall: the DA* 16-50 at 16mm f2.8 does not give me extra IQ.
I did not do these test with the DA* stopped at f3.5 and 18mm. IQ should improve...
The DA* advantages are: apperture (f2.8), weather sealing, 16mm vs 18mm and SDM.
The disadvantages are: weigth, size and price.
If that is worth the money, depends on how deep your pockets are I guess.
- Bert
01-06-2008, 09:44 AM   #5
QuoteOriginally posted by bymy141 Quote
- Bert
Thanks Bert for all that work. It sure helps me (and I assume others) in making a decision about this lens
NaCl (the production QA issues are still troublesome tho)H2O
01-06-2008, 11:23 AM   #6
16-50 works great
thats today the problem to get a good working piece!
Mine is realy great, very sharp, no problems with front- or backfocus. Its absolutely new out of the newest production.
You should try the lens at your dealer!
01-06-2008, 02:29 PM   #7
Fl_Gulfer's Avatar
Thanks Bert::: It just shows, for the price the Tamron is a great lens. I was going to get the 16-50 but when I started reading about the 2 lenses. I just couldn't resist the Tamron. Thanks for conferming what I thought.
16-50mm, copy, da*, k-mount, lens, owners, pentax lens, post, slr lens
Trouble with SMC F 50mm 1.7, request to F and FA owners tr13 Pentax SLR Lens Discussion 5 09-08-2009 11:53 PM
Suggestion for Sigma 24-70 owners (or potential owners) joeyc Pentax SLR Lens Discussion 4 08-07-2009 03:12 AM
Request for limited owners and K7 owners Psynema Pentax SLR Lens Discussion 0 07-09-2009 07:11 PM
Question for 16-50mm owners Itzik Pentax SLR Lens Discussion 1099 01-08-2009 10:38 PM
Lens Advise please Murphy2004 Pentax SLR Lens Discussion 4 10-21-2008 06:06 PM
All times are GMT -7. The time now is 08:03 AM. | See also: NikonForums.com, part of our network of photo forums!
