Originally posted by Verglace With macro a longer focal length is preferable
Often, but not always. Where having greater working distance is important, such as when shooting insects, yes. But there are times when a shorter working distance is better, as when using flash when you want highly diffused light. With a longer working distance it's harder to get the light source as close to the subject.
When I chose the Sigma 70 a few years ago, like the OP I had in mind that it would double as a portrait lens. But in fact I find I prefer a fast 50 or 55 for portraits. For one thing, 70mm @ f/2.8 doesn't give a particularly thin depth of field (at portrait distance) for those times when you want that effect. For another, as Bob pointed out, brutal sharpness isn't always wanted in a portrait lens.
I do a lot of macro so I use the 70 a lot, and I really like it. Niggles: no aperture ring, focus ring turns in the opposite direction from Pentax lenses, no quick shift, and I don't much care for the metal screw-in hood. It's still one of my favorite lenses.
For sample images,
nearly all most of these (check the focal length in the EXIF) are with the Sigma:
baro-nite's Album: Macro & Close-up - PentaxForums.com
