Originally posted by grainbelt I have done very little bird photography, but want to chime in with regard to the DA 55-300 and technique. Other than birds-in-flight, if you aren't getting it with the 55-300, you aren't close enough. I do find it a bit soft at the long end and wide open, but ~270mm and F/8, completely passable. The Quick-Shift capability of DA lenses comes in very handy in these situations, and I can second the hip-wader suggestion.
The DA 55-300 is a bit soft at 300mm and F5.8, but improves significantly even at F6.3 or F7.1 without any significant loss in exposure (only 1/3 or 2/3 stops). It is at its best at F8.
I found that the TAv mode being the best for birding with this lens under highly variable light condition as in tree foliage. Just set the camera to TAv mode, the aperture at F8 and the speed anywhere from 1/200 to 1/500 (whatever you feel comfortable) and let the ISO float. That way you use the lens at its best F-stop, you get a speed that will provide a blur-free image and let the light dictate the ISO and noise.
Or if you have a strong flash, set the aperture at F8 and keep shooting.
