03-07-2012, 01:47 PM   #1
yorik's Avatar
WR lenses and chlorine
Hi, I have a quick question...
Does anyone know how well the WR lenses (more specifically the special coatings) handle chlorine (at the pool)?
Thanks!
03-07-2012, 02:02 PM   #2
hcc
hcc's Avatar
First do beware that WR does not mean water resistant. WR means solely weather resistant.
A WR body+lens is not designed to be placed 'in purpose' in a pool.
Back to your query, this leaves the possibiity that you may shoot in a pool building with chlorine 'fumes'... While I have no direct experiene with chlorine, I shoot often on beaches with salt splahes and sand particles. So far I had no problem nor issue... but I take care of my gear. TLC. (Tender, Love and Care.)
This means that I always wipe regularly my gears, and I rinse them with freshwater after each day trip. I would do the same if I shoot near a pool.
Hope that the comment may help.
03-07-2012, 02:06 PM   #3
Docrwm's Avatar
Chlorine exposure can mean vapors but more likely means pool water that is chlorine treated. I've been looking for information on that as well and all I can find is generic information on AR coatings, like this one:
"Never clean your AR coated lenses with ammonia or products containing ammonia or chlorine."
03-07-2012, 10:53 PM   #4
Wheatfield's Avatar
If there is enough chlorine in the environment to harm your glass, you are already dead.
03-07-2012, 11:43 PM   #5
yorik's Avatar
Thanks for your replies!
To clarify, I am not thinking about chlorine fumes so much as pool water splashing the glass...
03-08-2012, 12:00 AM   #6
Anvh's Avatar
QuoteOriginally posted by yorik Quote
Just wipe it and afterwards just rinse it, i never had a problem so far.
And if you're really that troubled by it you can buy an protective filter but i atleast never used one.
03-08-2012, 06:14 AM   #7
Docrwm's Avatar
Glib answer but untrue. Coatings can be sensitive to specific chemicals and chlorine appears to be one of the ones that is used in the manufacturing process for many AR coatings.
03-08-2012, 06:47 AM   #8
Wheatfield's Avatar
QuoteOriginally posted by Docrwm Quote
And if the amount of chlorine is high enough to damage lens coatings, it is not an environment that a person wants to be in. The % of chlorine in swimming pool water is not high enough to do any harm to lens coatings (I and some friends shoot water polo tournaments, our lenses often get splashed).
No citations, so I'm dismissing your post as hysteria anyway, but lets use acetic acid as a metaphor. In low concentrations, you put it on French Fries, in high concentrations, you die because it burns your lungs.
chlorine, k-mount, lenses, pentax lens, slr lens, wr, wr lenses
Do m42 lenses measure up to todays lenses? Vantage-Point Pentax SLR Lens Discussion 25 05-14-2011 07:51 AM
Huge test on the influence of fungus in lenses (on 9 lenses) CarbonR Photographic Technique 18 03-14-2011 10:34 PM
For Sale - Sold: (3) Vivitar Series 1 70-210mm lenses + 3 Pentax lenses JP_Seattle Sold Items 13 04-23-2010 03:10 PM
Renting New Lenses vs. Buying Old Lenses ajtour Pentax SLR Lens Discussion 7 03-30-2010 06:39 PM
All times are GMT -7. The time now is 11:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
