03-29-2012, 08:41 PM   #31
The Pentax 50mm f/1.2 is the only lens that can beat the FA31 when it comes to bokeh.
Well, what about the Voigtlaender Nokton 58/1.4, or some of those old M42 preset Meyers?
03-29-2012, 09:22 PM   #32
mikeSF's Avatar
Pentax K-5 SMCP FA31mm f/1.8 Limited ASPH @ ISO 100 1/1250th f/1.8
Let me put it this way, there aren't many lenses that can produce smooth bokeh like that under those circumstances. The Pentax 50mm f/1.2 is the only lens that can beat the FA31 when it comes to bokeh.
and there ya go.
03-29-2012, 11:52 PM   #33
Digitalis's Avatar
QuoteOriginally posted by lytrytyr Quote
This isn't a discussion over which lens has the best bokeh, that topic has already been debated ad nauseum on these forums and when it comes to lenses in the 30mm to 35mm focal length category there aren't many lenses f/2 or faster that can match the FA31*. Even the Leica 35mm f/1.4 Summilux-M - doesn't hold much of an optical advantage over the FA31 on full frame, despite its exorbitant cost. Speaking of full frame, I use the pentax FA43mm f/1.9 Special - which is basically an FA43 with a 39mm screw mount that can be used on Leica cameras. On the Leica M9 the FA43 is a pretty good lens* - the corners are soft at f/1.9 but at f/4~5.6 it is as sharp across the entire frame as the Leica 50mm f/1.4 Summilux-M ASPH - and the FA43 is also more resistant to flare.
*I prefer to use the FA43 Special on the Leica M8.2 because it behaves more like a 55mm lens on the 1.3X APS-H sensor.
Pentax K-7 Pentax FA31mm f/1.8 Limited ASPH - ISO100 1/250th @ f/1.8
03-31-2012, 06:21 AM   #34
germar's Avatar
Addressing the OP's original question, I own both and for me the true test is which one get's more "seat time" on my K-5. I use the 43mm more, because the FOV seems truly normal for me and it works with my style of shooting. The color rendering, IQ and bokeh is very much in line with the 31 Ltd, just amazing images. I think someone here has suggested that you look at your historically most favorite focal length and base your selection on that. If you've shot more wide stuff, the 31 is your choice, if more normal/long the 43 is the way to go. In regards to pure image quality concerns, these two amazing lenses are very very close.
Also another small point: The 31 Ltd is very large and heavy compared to the 43. The 43 is only a few millimeters bigger than a DA40mm, and you can get the 43 pretty tiny by "borrowing" the flat lens hood off a 40mm. It works fine and makes the K-5 pretty stealthy.
04-01-2012, 11:04 AM   #35
QuoteOriginally posted by germar Quote
I cannot see how anyone would find the standard hood for the FA43 too large. And remember, the main purpose of a hood is to shade the lens from stray light. If you use a hood that is too shallow, you may lose some of that shading.
Rob
04-01-2012, 12:58 PM   #36
Ash
Community Manager
Ash's Avatar
The FA43 lens hood appears alsmost inadequate it's so small - it's perfect for FF, and it's definitely nicely completenting the original lens cap.
For a 1.5x crop dSLR, a larger hood would ward of stray tangential rays a little better, but then why mess with perfection?
04-01-2012, 02:16 PM   #37
rparmar's Avatar
QuoteOriginally posted by orangezorki Quote
Have to chime in for the 31mm as well - fantastic build and optics, but more importantly it seems to be a perfect 'normal' focal length.
Unfortunately for those who want a normal on APS-C, the FA31 comes in at close to 32mm focal length. That's a good way off the 28mm normal.
Everyone has different preferences, but I prefer 24-28mm or skipping up to 43mm -- the latter for obvious reasons!
QuoteOriginally posted by fmerges Quote
At the end I bought the 43mm, the 100mm macro was not the WR one. The 43mm I got is a silver one with serial number #0004338 Made in Japan.
You are going to enjoy that lens. But do consider manual focus for greater control and accuracy.
Have to get now a silver filter, any recommendations?
Filters kill IQ. The hood will protect the lens.
04-01-2012, 03:30 PM   #38
Ex Finn.'s Avatar
QuoteOriginally posted by rparmar Quote
Say what?. I must be missing something here so my apologies up front.
04-01-2012, 04:11 PM   #39
Digitalis's Avatar
because we can?
depending on where you are focusing. A lenses focal length can vary quite substantially at closer distances especially IF lenses, but it is usually within 1mm*/- tolerance.
scare words, if you have a high quality Hoya pro-1Digital or Schneider (B+W) you should be fine image degradation is kept to imperceptible levels.
04-01-2012, 04:51 PM   #40
As I understand it, the focal length is defined to be
the lens center to focus plane distance,
when the lens is focused at infinity.
04-01-2012, 05:08 PM   #41
Digitalis's Avatar
As I understand it, the focal length is defined to be the lens centre to focus plane distance, when the lens is focused at infinity.
But as you focus closer, the optical centre of the lens moves further away from the sensor.
04-01-2012, 05:11 PM   #42
True, but that increasing distance is not what is normally understood as the "focal length" of the lens.
See http://en.wikipedia.org/wiki/Focal_length
04-01-2012, 06:52 PM   #43
rparmar's Avatar
Scared? Who me?
You add a piece of glass to the front of your lens with two surfaces, neither of which were anticipated by the lens designer. By doing so, you also include an new air gap. The only result of this will be image degradation. Especially at night or when flare might be at risk. Yes, if you pay a lot for high-priced glass this effect might be minimal, but why bother? (And I emphasise "might" since many expensive filters are crap. This has been objectively tested and proven.)
In extreme environmental conditions (salt water, wind-born sand) it may be worth bothering with a filter. For day-to-day use you're wasting money.
04-01-2012, 06:53 PM   #44
rparmar's Avatar
This is obviously some new definition of "focal length" of which I was not previously aware. Seems to me you're talking about "focus distance" or "subject distance".
But regardless of whether we are talking 31mm or 32mm, that's not "normal" for APS-C.
04-01-2012, 08:38 PM   #45
Digitalis's Avatar
Then why do they put filter threads on the front of lenses if they do not anticipate photographer to use filters? why does the Pentax D-FA 645 25mm f/4 - a lens designed for medium format, have a built in 40.5mm filter drawer?
With modern multi-coating techniques the air gap is less of a problem than it was for uncoated lenses. If you use a quality multi-coated filter there shouldn't be any observable difference, however at night times when there are many point light sources in a scene it will be beneficial to remove filters because ghosting and filter flare can become serious issues.
43mm, k-mount, kit, lens, ltd, pentax lens, slr lens
43mm... sell my 50mm and 35mm for a 31mm? krypticide Pentax SLR Lens Discussion 60 08-01-2011 01:37 PM
For Sale - Sold: Pentax FA 31mm/1.8, FA 43mm/1.9, DA 35mm/2.8 Macro, DA 12-24mm, AF160 flash (U farfisa Sold Items 15 12-10-2010 02:00 PM
For Sale - Sold: FA Limited 31mm, 43mm, 77mm and Metz 48 AF-1 (US) jpfisher Sold Items 17 08-05-2010 07:22 AM
For Sale - Sold: Pentax Limiteds 43mm/31mm/77mm, FA * 200mm, K10D, TC Dave Sold Items 20 06-17-2010 09:08 PM
All times are GMT -7. The time now is 06:23 AM. | See also: NikonForums.com, part of our network of photo forums!
