Originally posted by eddie1960 (the Topcon mount is the same minus the big arm out the side so maybe welby made a Topcon as well)
Some Exakta-mount lenses have the big-arm stop-down button, some don't. There's a way to remove it, but it's messy.
Quote: exacta cannot be adapted to K mount (44.7 mm reg distance vs k mount 45.46mm)
Ah, but it can be finessed! I use a number of armless Exakta-mount lenses on my K20D. The procedure is very simple:
1) Get a cheap clone thin-flange M42-PK adapter, and a chunk of rubber or soft wood.
2) Remove the index screw on the lens base. Save the screw if you ever intend to use the lens on an Exakta again.
3) Use contact cement to glue a cheap M39-M42 adapter ring around the lens bayonets.
4) While the glue is drying, tape a piece of 100-grit sandpaper to a very flat hard surface like a kitchen tile. Put the M42-PK adapter flange-down on the sandpaper. Use the rubber or wood as a grip while you grind away about 0.7mm from the flange. Don't remove too much of the thin flange or the adapter won't seat on the camera's PK mount.
5) When the glue is thoroughly dry, thread the ground-down adapter onto the lens, then mount it on your camera. Check to see if you have infinity focus. If not, grind a little more, but not too much (as I warned above).
In the last few days I've used the following Exakta-mount lenses via this solution:
* CZJ Tessar 50/2.8 (12 iris blades)
* Meyer Primagon 35/3.5 (retrofocus)
* Meyer Helioplan 40/4.5 (pancake)
* Isco Westar 100/4.5 (long lens)
The Primagon doesn't quite reach infinity-focus wide-open, but infinity is in focus when stopped-down to f/8.
I also have a Kilfitt Makro Kilar-E 40/3.5 (not with me at the moment) whose index peg is not removable, so the procedure for adapting it is slightly different:
6) Grind-down an adapter as above, and cut a small notch in the thin part of the ring so it seats over the lens index peg.
7) Thread an M39-M42 ring inside the the ground-down adapter.
8) Glue the threaded adapters onto the lens' bayonets.
All these are fairly small light-weight lenses. I don't think I'd try this with a 200/3.5 weighing 500g or so.
