03-13-2012, 12:53 PM   #1
KA mount lenses won't fully attach on a K-X
I just bought a K-X to use with my old lenses. My SLR was all-manual, so most of my lenses are M, but two are A - I just didn't use the A feature on them at the time.
The M lenses work great - I've read up on all the settings and they are working fine. But the A lenses (an Exacta 70-210mm zoom and an Exacta fixed 28mm) won't attach properly. When mounting them, they turn about halfway and then stop, before the locking button pops out to indicate that they are locked in.
I've tried attaching them with the aperture set to "A" and with it set to a fixed value. I've compared the lever and the flange to the lenses that work, and I can't see any difference. I can't see any protrusion that would explain this. Does anyone here have any ideas or experience with this?
Many thanks,
CBH
03-13-2012, 12:57 PM   #2
Don't force anything. Find out what prevents the lens from turning in the mount.
It can be because of the flange (or shroud) that "protects" the aperture lever on the lens is too wide. If that's the case, you'll need to trim off the flange or remove it.
Read this post.
03-13-2012, 03:16 PM   #3
Are they Ricoh-mount (KR) lenses?
03-13-2012, 03:22 PM   #4
aleonx3's Avatar
Some of the third party lens have the lever guard (flange) too high unless you file it down or remove it, you are not able to mount it properly. You can mount it on the old film camera but not an APS-C DSLR. Unless if it is a very stellar lens, I don't think it is worth the time to fix it (at least in my case).
03-17-2012, 07:36 PM   #5
They are not KR's, although that was a good thing to check - I had heard about the Ricoh pin problems.
03-17-2012, 07:40 PM   #6
It is not the flange. I thought it might be, even though the flanges look just like the ones on lenses that work. But to be certain, I removed and isolated just the metal ring on the lens - I separated away, the flange, the bayonet, and the lens itself. Even just the metal ring has the problem. I compared it carefully to the ring on a lens that works, and I can't see a difference.
I suppose I should give up. My attachment is sentimental. I learned to shoot with these lenses, and I liked the idea of still using them.
03-17-2012, 07:51 PM   #7
Docrwm's Avatar
QuoteOriginally posted by cbhicks Quote
A couple of pictures of the mounts may get you some answers here. Try posting a couple from different angles and see if folks can't help you out.
exacta, k-mount, k-x, lenses, pentax lens, slr lens
New Sigma 150mm macro might/will/won't??? come in K-mount robjmitchell Pentax News and Rumors 145 02-18-2012 07:55 AM
K-x aperture problem: always fully stopped down on DA lenses amrocha Troubleshooting and Beginner Help 4 11-03-2011 03:47 PM
MF Lenses that won't break the bank paolojackson Pentax SLR Lens Discussion 9 09-22-2011 04:33 AM
Optio A36 Fully powers up, then fully powers down. PicturePlant Pentax Compact Cameras 6 08-11-2011 11:45 AM
Why do DA lenses stop down fully on pre-A cameras? Spock Pentax SLR Lens Discussion 8 01-20-2011 06:03 AM
All times are GMT -7. The time now is 01:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
