03-19-2012, 03:06 PM   #46
Ben_Edict's Avatar
QuoteOriginally posted by westmill Quote
I can honnestly say Ive never had a problem using filters. Although I wont use
anything other than Hoya PRO.
I have had massive flareing and ghosting when I accidentally had UV filters on my faster lenses (FA 24/2.0, FA 50/1.4, FA 35/2.0) on a series of night shots. The number of street lights in some shots doubled - and the shots were largely ruined. Since the day I saw these results, I made sure I only use filters in certain circumstances, where there use is really neccessary. And I also use only B+W and Hoya Pro 1 filters, even for those ruined night shots.
Ben
03-21-2012, 09:48 AM   #47
jpzk's Avatar
QuoteOriginally posted by Pål Jensen Quote
I have never said it is the worst lens produced by Pentax. The lens is excellent (exept for corner sharpnes at wide aperture and some fringing). However, it is probably the most flare prone lens Pentax have made. At least it the most flare prone lens I've ever seen; it flares more than the fish-eye zoom!
Point it at the sun; stop it down to F:22 and engange DOF preview. See what happens in the finder....
Again, the lens is clean.
The lens is apparently due for replacement and I suspect its bad flare performance could be one reason....
I will replace mine in due course with the Limited zoom + the 15 Limited....
Sorry that I misinterpreted your posts, Pal.
I think, like you are mentioning, that maybe this lens is faulty ? But, I am guessing.
I hope you will have more luck with the DA 15 Ltd ... I own one and it is a great lens indeed.
Cheers.
JP
04-12-2012, 05:05 AM   #48
Mareket's Avatar
Wow, have you EVER used the FA 50? Mine flares like a demon if I so much as consider going out without a hood on.
I had a DA 15 Limited and sold it, and now I have the 16-50 and I find it a far superior lens. It flares, yeah, but I knew it would because the front element is about as big as my face.
I do miss having a tiny metallic chunk of beauty though The 16-50 is a hefty chap.
k-mount, pentax lens, slr lens
Thematic A Flair for Flare jheu02 Mini-Challenges, Games, and Photo Stories 563 5 Days Ago 07:57 AM
Measurement of lens flare (veiling glare) with and without UV filter labnut Pentax DSLR Discussion 4 05-14-2011 09:13 AM
Nature Tame, yet wild, rabbit topgun Post Your Photos! 3 05-10-2011 11:56 AM
What is this (flare?) ? sterretje Pentax SLR Lens Discussion 15 05-03-2011 08:37 AM
Manfrotto 359 Long Lens Support with gimbal head? need to tame the SMC 1000mm tvfd911 Pentax Camera and Field Accessories 9 05-08-2010 05:51 PM
All times are GMT -7. The time now is 10:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
