03-14-2012, 03:33 AM   #1
what filter to tame da*16 50 flare?
Hoya UVO good enough or CPL?
03-14-2012, 03:35 AM   #2
westmill's Avatar
I use Hoya PRO, but there is no substitute for a good lens hood.
03-14-2012, 03:46 AM   #3
flare comes from light bouncing around inside the lens, no filter can stop flare if such a magical filter existed, i'd love to throw it on my da*55...
03-14-2012, 04:07 AM - 1 Like   #4
Zav
Zav's Avatar
A filter will create flare...
03-14-2012, 04:21 AM   #5
I really want to find good reason to buy the 16-50, looks like I run out of excuses.
03-14-2012, 04:29 AM   #6
jatrax's Avatar
Flare is often caused by filters, or at least made worse, especially by cheap ones. What you need is a lens hood. A CPL is good for many things, darkening the sky, reducing glare from reflections off water or plant leaves but not flare. Get a good lens hood and keep it on the lens.
03-14-2012, 05:24 AM   #7
I really don't find flare on the 16-50 to be that bad as long as you don't put filters in front and keep your front element clean. I know others have reported more problems with it, but it isn't that bad...
03-14-2012, 05:27 AM   #8
Aren't the stock one good enough? It breaks my heart to read the Pentax, sigma and Tamron shoot out. A wr 16 50 is important to me. Maybe the mark II is around the corner.
03-14-2012, 05:32 AM   #9
westmill's Avatar
You could always opt for the 17-70 F4 !!! Its a cracker ! and slightly better range too !
03-14-2012, 06:51 AM   #10
But it ain't wr, right?
03-14-2012, 06:53 AM   #11
f 16?
03-14-2012, 07:09 AM   #12
steve1307's Avatar
Leave the lens cap on. The only way to gaurantee no flaring when shooting into the light.
Use the hood and also shade the lens from direct sunlight if it is outside your frame of view.
I have found that any filter, even the best CPL can only make it worse not better.
03-14-2012, 07:11 AM   #13
Tell that to my DA 15:-P
03-14-2012, 08:15 AM   #14
QuoteOriginally posted by lightbulb Quote
f 16?
I think it is 16mm f8. However flare is pretty much the same as that from f4 on.
03-14-2012, 09:04 AM   #15
jpzk's Avatar
I use my DA*16-50 quite a bit with my K7, sometimes with the K5, and I have yet to report continuous flare with that combo.
I do NOT use a filter and I make sure the hood is used as well.
I have used filter(s) with this lens but I found that it caused quite an IQ hit ! And the filter(s)
were of excellent quality too.
JP
k-mount, pentax lens, slr lens
Thematic A Flair for Flare jheu02 Mini-Challenges, Games, and Photo Stories 502 03-15-2017 12:36 PM
Measurement of lens flare (veiling glare) with and without UV filter labnut Pentax DSLR Discussion 4 05-14-2011 09:13 AM
Nature Tame, yet wild, rabbit topgun Post Your Photos! 3 05-10-2011 11:56 AM
What is this (flare?) ? sterretje Pentax SLR Lens Discussion 15 05-03-2011 08:37 AM
Manfrotto 359 Long Lens Support with gimbal head? need to tame the SMC 1000mm tvfd911 Pentax Camera and Field Accessories 9 05-08-2010 05:51 PM
All times are GMT -7. The time now is 12:10 AM. | See also: NikonForums.com, part of our network of photo forums!
