03-18-2012, 10:02 PM   #16
raider's Avatar
I have the B+W ND1000 49mm which is great. For CPL, the best is the Hoya Pro1 Digital but 52mm is the smallest, so I am using a 49 to 77mm step-up on a 49mm neutral filter and I don't have vigneting.
I am assuming u are using a sacrificial 49mm filter (with the lens punched out) + a 49-77mm step up ring + a 77mm ND filter?
And u dont vignette with that?
03-18-2012, 11:22 PM   #17
mikeSF's Avatar
i use 49mm screw in filters on the DA15 without any problems.
for a GND, i would not consider a round filter but rather a square (Cokin-type) filter. Cokin makes a wide angle filter holder which works fine with the DA15 with minimal vignetting but you need a single empty filter ring to clear the hood.
03-25-2012, 09:37 AM   #18
Clarkey's Avatar
QuoteOriginally posted by mikeSF Quote
+1 on this. I have a cokin 49mm ring permanently attached to the lens.
I have a cokin "A" system on a square holder.
I typically shoot with an ND6 grad (cokin), and a CPL with this set up. Without the CPL, I don't get vignetting. If using, I crop.
Total cost of set up was around $40.
I'll put it together, and post a picture.
03-25-2012, 10:01 AM   #19
mikeSF's Avatar
so just to be summarize, you only need an empty filter ring spacer if you are stepping up to a larger filter and need to clear the protruding hood.
i have a similar solution to the fixed hood of the FA31 for which i use two empty 58mm rings attached to my Cokin P holder.
03-25-2012, 10:02 AM   #20
reeftool's Avatar
I have used a Hoya ND400 (9 stop ?) and a B&W CPL without problems on my DA15. Another reason to buy Limiteds is the 49mm filters fit most of them along with a lot of other vintage Pentax glass.
03-25-2012, 10:14 AM   #21
Na Horuk's Avatar
QuoteOriginally posted by reeftool Quote
Does the CPL cause odd shades in the open clear sky?
03-25-2012, 10:49 AM   #22
Yes it can (and will), particularly if you shoot in landscape orientation.
That's right, it's a 9 stop filter. The B+W ND 3.0 is a 10 stop filter.
Perhaps my spacer filter is a bit too wide, because I get a little more than "minimal" vignetting when I've tried this. I'm hoping for better luck with Lee system wide angle adapter to use with my Lee system.
03-25-2012, 02:12 PM   #23
mikeSF's Avatar
QuoteOriginally posted by northcoastgreg Quote
i have no issues but my ring is just thick enough to bite the threads leaving no clearance at all.
I have the P size cokin wide angle holder, FWIW. I just shot several test pics with and without the holder with a filter and only see a slight hint of vignette in 2 corners when shooting wide open which i would never do using filters. Not a trace of vignetting once stopped down a few clicks.
03-25-2012, 06:35 PM   #24
That's how CPLs work on wide angles. The closer to the Sun you point the camera, the brighter the sky will be, the further away, the darker it is. Since wide angle covers large part of the sky, you will see different shades of sky. I don't mind that look.
03-25-2012, 10:15 PM   #25
reeftool's Avatar
The couple of times I used it on the DA15, no. It gets used much more often on my other 49mm filter sized lenses. I've heard of issues with CPL's on ultra wide lenses. I mainly commented that it does fit the DA 15 if you care to use it. So far, every 49mm filter I own will fit into the DA 15 although I rarely use a filter on it. CPL's do change the shade of the sky some. That's one of the reasons why we use them. It performed as I expected it to.
03-26-2012, 02:05 AM   #26
fs999's Avatar
QuoteOriginally posted by raider Quote
Yes ! (Sorry for the delay)
I used prior a 49 to 52mm step-up, but then I had vignette.
03-26-2012, 05:24 PM   #27
Clarkey's Avatar
Here you go. The 49 mm ring is a cokin extension ring.
I get vignetting with the CPL, as mentioned, and pictured,but as I am printing 8x10's most of the time, it is rarely an issue.
I've just happily realized that along with my 15, 40, 50, and 70mm lenses, I can also use the NEX kit lens with this rig.
PENTAX K-7  Photo
NEX-5N  Photo
filter, gnd, k-mount, lens, ltd, pentax lens, quality, rings, screw, slr lens, step
Single 52-72 step up ring or 52-72 set? geekette Pentax Camera and Field Accessories 11 05-20-2011 09:13 PM
43mm to 42mm Step Down ring? goldenarrow Ask B&H Photo! 6 06-02-2010 09:30 PM
77mm CPL on DA 15mm step down ring Alex00 Pentax SLR Lens Discussion 3 05-15-2010 08:21 PM
step-up ring vs different size filters math guy Pentax SLR Lens Discussion 8 04-21-2010 09:43 PM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
All times are GMT -7. The time now is 03:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
