Originally posted by Tomm @lytrytyr: Sounds as a pretty good idea actually! I was thinking about a DA 55-300 in the future but I guess your option is way lighter and compact, or am I wrong?
Tammy + M100/2.8 will certainly be heavier than just the DA18-135, of course.
The Tammy alone is only slightly heavier, and about 1cm longer.
The M100/2.8 is about 225gm, 56mm long, half the size and weight of the DA 55-300.
Originally posted by Tomm How are the manual focus capabilities, easy enough?
Since the M100 is only f/2.8, it's not as snappy to focus manually as a sharp f/1.4 lens,
but still relatively easy once you get used to it.
For 100 Euros, you can't go too far wrong,
and if you do decide that manual focus with that lens doesn't work for you,
you should be able to sell it on quite easily.
