01-18-2008, 11:42 AM   #106
QuoteOriginally posted by kenyee Quote
If that's true, they should attach another set of blades at an N degree offset to the regular blades. This would give you a better approximation of a circle which it seems is what they really want for better bokeh? I.e., the more blades/sides to the simulated circle, the better the bokeh?
This is one of the factors, yes. (And I would love for Pentax to come out with rounded aperture blades in the future.) But even if the aperture blades are perfect circles, they are still diffracting the light, and there are still inherent characteristics of the glass itself - hence the bokeh characteristics that apply both wide open and stopped down.
01-19-2008, 03:20 AM   #107
Dueling Definitions
QuoteOriginally posted by mer Quote
hey jonas
interesting post . I am not really sure that bokeh = "quality of the out of focus parts of the picture", as in japanese bokeh , literally means "blur" / "fuzziness" .
Wikipedia says : Bokeh (from the Japanese boke ぼけ, "blur") is a photographic term referring to out-of-focus areas in an image produced by a camera lens. ...
From The Photographic Glossary: your Photo help page : Bokeh describes the rendition of out-of-focus points of light. Differing amounts of spherical aberration alter how lenses render out-of-focus ...
As I learned the term in the late '70s, and have often seen it used since, the definition given in The Photographic Dictionary best identifies the core of the Japanese concept. The rendition of out of focus points of light is what I always look at when someone discusses the bokeh in a photograph. It's what I always assume when someone says "lens X has nice bokeh." General OOF areas, whether foreground or background, are areas of falloff from the depth of focus in a particular image, usually described by the circle of confusion for a given point in the image exceeding some "acceptable" value. Hence, both types of description of OOF (points of light versus circles of confusion for a specified point) are a bit subjective (alright, downright fuzzy!) and really, if there is a meaningful difference in the concepts, I think the former involves description of a highlight point while the latter involves description of more middling toned areas.
Now, how about those angels on that pinhead over there?
01-19-2008, 06:45 AM   #108
Rickster's Avatar
QuoteOriginally posted by d.bradley Quote
To throw something completely different into the bokeh mix, check out these examples:
Shot with the Minolta 35/1.4, you can see concentric circular texture in the specular highlights...never figured that one out...
Diffraction Rings. The offset nature of the diffractions rings in the image above seems to indicate a centering or collimation defect in that lens.
For further reading check out "Star Test" for astronomical lenses aka telescopes.
01-19-2008, 09:33 AM   #109
QuoteOriginally posted by Rickster Quote
Hey Rick,
I don't know about a defect. You could be right, but the concentric rings change placement depending on where the highlight is within the image frame...specular highlights on the right side of the frame are offset to the right, ones in the upper left offset to the upper left...
01-19-2008, 10:38 AM   #110
Rickster's Avatar
Hey Rick,
Yep, and orientation will switch 180 degrees if the 'star' object is in front of the focal plane vs behind.
01-20-2008, 09:56 AM   #111
Hey Sean and Jonas,
The 85/1.8 SMC Tak was getting flak on another forum for rendering, but blades aside I think it does pretty well in a tough situation:
03-06-2008, 03:09 AM   #112
blende8's Avatar
A different kind of Bokeh:
An image consisting almost exclusively of Bokeh.
This is on the beach, setting the camera on the ground and shooting against the sun.
The reflecting grains of sand create a prism-like appearance.
Nokton, f4.0
Taken from my full test of the Voigtlander Nokton:
Voigtlnder Nokton 58/1.4 and Pentax 50mm lenses
03-06-2008, 03:18 AM   #113
roentarre's Avatar
That is a very beautiful bokeh! Neutral but smooth creamy mixed with colours
03-06-2008, 10:23 AM   #114
wtlwdwgn's Avatar
This has been a fascinating discussion. Thanks to all for sharing. I've enjoyed learning from your experiments.
background, bokeh, definition, jonas, k-mount, lens, lenses, pentax lens, question, slr lens, thread
Guess the lens - 1.4 and 1.7 50 vs 16-50 Egg Salad Pentax SLR Lens Discussion 8 10-11-2009 03:26 PM
Guess the lens? bschriver11 Post Your Photos! 5 08-08-2008 04:26 AM
Guess the lens Mike.P Pentax SLR Lens Discussion 8 07-23-2008 02:13 AM
Guess that lens! tybeck Pentax SLR Lens Discussion 27 05-29-2008 09:35 AM
Surprising lens flare with Sigma 18-50mm f2.8 Jim Royal Pentax SLR Lens Discussion 16 03-13-2008 07:44 PM
All times are GMT -7. The time now is 08:35 PM. | See also: NikonForums.com, part of our network of photo forums!
