07-29-2018, 11:05 AM - 2 Likes   #2521
PALADIN85020's Avatar
QuoteOriginally posted by Kevin B123 Quote
She looks a little cutie, and will be a lot of fun.
What breed is she?, the puppy fat and ear size make me think she is a medium sized breed.
Since she was a stray, we have no idea as to her parentage. She has the long body and short legs of a Dachshund, but the face of a terrier of some sort. I suspect some of both!
John
07-29-2018, 12:07 PM   #2522
QuoteOriginally posted by ehrwien Quote
I don't know, I guess not. But I could certainly have restored some pop with the saturation and vibrancy sliders. And for the next time I'll just try to get the exposure correct (wrt the subject, not the whole frame) when taking the picture
I don't know how many shots I've ruined shooting against a bright sky like that, so I definitely know the feeling. All in all, I wouldn't be disappointed with the first ones you posted (but then I usually prefer slightly underexposed shots). Also, framing and capturing small birds is never easy, so kudos for doing it so well!
07-29-2018, 03:38 PM - 1 Like   #2523
Des
Des's Avatar
I use DxO which lets me adjust Highlights, Midtones, Shadows and Blacks separately from each other. I raised the Shadows for the overall photos and loaded the original and the boosted ones as layers into GIMP, where I masked out just the bird / the insect with a layer mask and a brush. These are the results of that process:
They are all an improvement on the original, particularly the first two. A little extra vibrancy might help but I wouldn't increase the saturation. If you deepen the blacks a little you might get more apparent contrast back.
I use DxO as well. One thing to try (assuming you have PhotoLab or a recent version of Optics Pro) is under "Smart Lighting", click the "Spot Weighted" button and select the darkest point on the subject (using the "Tool" button). Then try Medium or Strong mode. That should help. If you have PhotoLab, you could also try using "Local adjustments"; select the area to lighten using AutoMask, then adjust the exposure.
It's always tricky dealing with a subject in deep shadow against a bright background. Often you have no choice. Fill flash does help a lot if you don't overdo it. The trouble with flash is that you are usually limited to the flash sync speed (1/180th second on the K-S2), so you are at risk of subject movement or camera movement. The only way to get a faster shutter with fill flash is to use an external flash which does HSS - and that is quite distance-limited.
07-29-2018, 03:42 PM - 7 Likes   #2524
Des
Des's Avatar
07-30-2018, 11:17 AM - 6 Likes   #2525
UncleVanya's Avatar
07-30-2018, 02:32 PM   #2526
Des
Des's Avatar
Fine pair of images UV. Always striking how well this lens does portraits. The thread overall probably doesn't represent how much the 18-135 is actually used for portraits - probably because they are disproportionately shots of family and friends and not intended for publication.
07-30-2018, 02:34 PM   #2527
UncleVanya's Avatar
QuoteOriginally posted by Des Quote
Fine pair of images UV. Always striking how well this lens does portraits. The thread overall probably doesn't reflect that strength.
I agree that this is a much better portrait lens than most give it credit for. However the trend towards bokeh being king in portraits may have a bit to do with it. Selecting an appropriate background goes a long way.
07-30-2018, 11:56 PM - 3 Likes   #2528
Des
Des's Avatar
Rhyll jetty, Phillip Island, Victoria (x-posted)
07-31-2018, 04:02 AM - 2 Likes   #2529
NS_Sailor's Avatar
Managed to capture these cropped images (approx 25% of original) of this fellow with supper last evening through a screen door
PENTAX K-70  Photo
PENTAX K-70  Photo
07-31-2018, 05:03 AM   #2530
QuoteOriginally posted by NS_Sailor Quote
Through a screen door? So you just focused through it? If so, I'm amazed that these are reasonably sharp. Well done! That must be like a very rudimentary ND filter, i suppose?`
08-01-2018, 03:03 AM   #2531
I particularly like the shadows on picture two. Hell of a lens. I am playing with a new 21mm limited but find myself hankering for my 18-135 again
08-01-2018, 02:50 PM   #2532
Des
Des's Avatar
QuoteOriginally posted by Cerebum Quote
Thanks for your comment. Yes I loved the shadows too. Tweaked the tone curve a little in post, but even SOOC it was very good. The first two of these shots were at 36mm f11 and the third at 24mm f8, which are pretty much optimal settings for resolution on the 18-135. At these settings, and in these sorts of conditions, I think there wouldn't be much difference between the 18-135 and your 21 Ltd or my 20-40 Ltd - which is some tribute to the 18-135.
08-11-2018, 07:33 AM - 5 Likes   #2533
amateur dirt farmer
pepperberry farm's Avatar
08-11-2018, 08:37 AM - 8 Likes   #2534
Sunset yesterday. Another great reason to adopt a dog, he shares this with you
---------- Post added 08-11-18 at 08:39 AM ----------
QuoteOriginally posted by pepperberry farm Quote
I love the colour contrast. These pictures are so sharp!
PENTAX K-3  Photo
PENTAX K-3  Photo
08-15-2018, 02:53 PM - 1 Like   #2535
Des
Des's Avatar
Love the chooks @PepperberryFarm - you should cross-post in the farm animals thread.
balance, bike, creek, da, dog, exposure, factory, flickr, house, k-mount, nov, pentax lens, philippines, pm, post, scenes, shot, shots, slr lens, snow, subject, sun, tamron, tool, tower, trail, wr
XR Rikenon 135/2.8 OR Carl Zeiss Jena 135/3.5 (zebra) adicaciula Pentax SLR Lens Discussion 2 02-20-2012 02:29 AM
Takumar 135 2.5 vs Super Tak 135 3.5, both bayonet mount, which is better? chongmic Pentax SLR Lens Discussion 7 04-09-2011 11:55 PM
All times are GMT -7. The time now is 11:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
