Originally posted by Oktyabr Maybe it has something to do with camera firmware and it's internal profile for this lens?
You could try saving as RAW and make comparisons with post-processing software, but AFAIK the built-in profiles will adjust only distortion by lens ID and adjust colours by camera body. Random noise is a function of the sensor and the camera's processor, but some lenses produce images with more contrast, even if the files are processed the same and better contrast looks less noisy/grainy. Aperture and focal length also play a role in how distinct the changes in colour appear and while the 55-300 doesn't offer wider apertures or more contrast at the same focal length, at longer focal lengths you will get more subject isolation from telephoto compression. Another possibility is a decentered lens or problems with back or front focus. The D-FA 100 Macro is a sharper lens and lets in more light, the f1.7 50's have less distortion (and no auto-focus problems
), but when I compare apples to apples between the DA 18-135 and DA 55-300, the results are very similar.
