Originally posted by mgvh Don't get me wrong. I love my 18-135, and it's my primary lens, but the Tamron SP AF 24-135 f3.5-5.6 AD Aspherical (IF) does provide better pics. (
HERE is my review of that lens.)
I'm using the DA 18-135 because it's WR, lighter, and wider.
I'm keeping and using the Tamron 24-135 because of its outstanding IQ, excellent photo qualities of sharpness and contrast, and its full-frame capability (should I ever need it!).
The photo zone numbers tell a different story, as in a completely different story.
Pentax SMC-DA 18-135mm f/3.5-5.6 ED AL [IF] WR - Review / Lens Test - Analysis Tamron AF 24-135mm f/3.5-5.6 SP AD Aspherical (IF) - Review / Lab Test Report - Analysis
The Tamron is a more consistent lens, but only because it's centre resolution is so much worse... no where in it's range does the Tamron approach the Pentax's centre sharpness, and wide angle, the Pentax is better centre and edge. Looking at the photo zone numbers it's hard to believe the Tamron could match the 18-135 anywhere in it's range, except on the edges. Certainly no where near the middle of the frame.
I don't have both lenses, and I can't do a comparison, so I have no idea what's going on, so if you could do a comparison, at 24 mm or a few test images, using both lenses(tripod, 2 sec. delay on the timer, and a target image with a bit of detail) I'd be really interested in seeing if I see what you see.
I know the scores are achieved on different sensors and aren't directly comparable, but I've never known them to be that far off and I've used cross camera comparisons lots of times with good results. A couple of hundred lw/ph you can't be definitive, but you can certainly draw conclusions from the graphed ratings. You couldn't break a tie, if the lenses are this far apart, you're pretty safe assuming the one rated up in the excellent part is better than one very good to good.
