03-26-2012, 06:23 PM   #1
pentax 70mm with K-5 overexposure
i just bought the pentax 70mm pancake lens for my K5 and the first thing i am noticing is that my photos are overexposing, especially when stopped down to f8. i typically set the camera to aperture priority and find i need to set exposure compensation to -2. is anybody else seen this problem?
thanks,
eric
03-26-2012, 06:33 PM   #2
Lens mounted properly?
Same problem with the lens on a K10D?
Sticky blades (not to be expected with a new lens)?
03-26-2012, 06:38 PM   #3
thanks, i was wondering about the blades. i will try it on a k10d when i get back from my trip.
03-26-2012, 08:14 PM   #4
calsan's Avatar
Just check the exposure mode dial hasn't been bumped first...
03-26-2012, 08:28 PM   #5
I find my K-5 tends to over expose things, and I usually have to set my camera similarly. Perhaps that's my fault though
03-27-2012, 10:05 AM   #6
i checked everything. what i find strange is that it overexposes.more and more as i stop it down. i was just wondering if this lens might be defective in some way.
thanks.
03-27-2012, 10:41 AM   #7
QuoteOriginally posted by Eric Seavey Quote
Maybe the chip is bad. Can you still return the lens?
03-27-2012, 10:50 AM   #8
hello,
i did have a dfa100 with a similar problem ( https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/175134-problem...resistant.html )
fortunately amazon let me exchange, no problems so far
03-27-2012, 11:02 AM   #9
From OP's replies above, it seemed like the blades were OK.
03-27-2012, 11:17 AM   #10
Lowell Goudge's Avatar
anyone considered a bad contact or dirt on either the lens or body contacts.
try mounting and dismounting a few times.
something like the DA70 is too new to have sticking aperture blades unless it was very badly abused
04-07-2012, 03:57 PM   #11
Update.... I guess it is sticky blades causing the problem. I can actually see it when looking into the lens from the front when I do the aperture preview. Basically when stopping down to f/16, I am getting different sized openings every time, and the shape of the aperture is not circular either. Hopefully my replacement will be better.
Eric
k-mount, pentax, pentax 70mm, pentax lens, slr lens
Flash overexposure with new K5 dh87 Troubleshooting and Beginner Help 36 08-05-2011 04:12 PM
AE-L Overexposure workaround dande Video and Pentax HDSLRs 6 12-14-2010 05:02 AM
K20D overexposure billmcf Pentax DSLR Discussion 5 08-25-2010 06:36 AM
K-x overexposure? kevingt01 Pentax DSLR Discussion 5 05-17-2010 12:45 AM
Pentax 18-250 and k10d overexposure problem j1mallen Pentax SLR Lens Discussion 2 07-14-2008 05:11 PM
All times are GMT -7. The time now is 01:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
