01-10-2008, 01:10 AM   #1
Is there a mount for Minolta lenses, on a k10d body?
I have a bunch of old minolta film lenses, and I would like to use them on my k10d.
Does anyone know of a mount that would let me use these?
01-10-2008, 02:03 AM   #2
Yep, it's called a Sony A100, A200 or A700. (will do mostly the same stuff a K10D will do).
The only K-mount adapters that exist are M42 to K, Pentax 645 to K, Pentax 67 to K, and the Tamron Adaptall T-mount adapters.
01-10-2008, 02:36 AM   #3
I don't know any for either MD or A mounts, sorry.
Would luuurve to get me mitts on the 135mm STF...
01-10-2008, 07:49 AM   #4
Nesster's Avatar
Whether a mount will work and permit infinity focus depends on the flange to film distance. Makes that have a longer distance can be adapted to a body with a shorter distance - for example, back in the day, Konica had a short distance and therefore nearly any other lens could be adapted.
Minolta's distance is shorter than Pentax, therefore no mount.
Lens mount - Wikipedia, the free encyclopedia
01-10-2008, 08:04 AM   #5
Nesster's Avatar
Looking at the Wiki table, I see why Canon seems to have mounts for so many other lenses... not that stuff like metering will work, but at least the lenses can focus to infinity.
01-10-2008, 01:05 PM   #6
ryan s's Avatar
Right, the MD to K is not going to happen If you did take the time, there would be no infinity focus.
The EF Canons have an almost perfect register distance.
My Canon is off by one full stop either over (90% of usage) or under (less light) in Av mode. It's rare to get a perfect exposure without using M. But, other's mileage varies and some can use Av without issue.
01-10-2008, 02:49 PM   #7
ok, thanks for the article, that makes sense.
01-10-2008, 08:59 PM   #8
QuoteOriginally posted by SupremeMoFo Quote
i don't believe old Minolta MD lens works with new Minolta camera (not as well as K lens working with new Pentax camera)
01-10-2008, 10:10 PM   #9
You can only use Minolta MD and MC mount lenses with an adapter on the Sony/Konica-Minolta A-mount cameras. These adapters also have a glass element in order to achieve inifinity focus and badly degrade image quality.
You can use MC/MD lenses on Olympus 4/thirds cameras with an adapter
The Rokkor Files - the Four Thirds Future
06-13-2008, 10:40 PM   #10
Pentaxians,
Yesterday, I did sucessfully convert the Minolta MC Rokkor-PF 58/1.4 into P/K. I repeated almost exactly the same as cogitech in his instruction of converting the Minolta 58/1.2 to EOS How to Convert Your Minolta MC Rokkor 58mm f1.2 Lens to Canon EOS Mount . The only extra work is to sand the lens mount shim a little more. This helps the lens focus to infinity due to the longer register distance of P/K compared to EOS.
Everything works fine and here are some sample shots of the Minolta MC Rokkor-PF 58/1.4 on my K10D
06-14-2008, 12:34 PM   #11
Big Dave's Avatar
ranamar,
The minolta MC 1.2 mount is better suited for conversion then the other MC series. I have both and the newer MD series is well suited to conversion. The finished lens with the new K mount must seat 2mm further from the sensor/film plane for Pentax. I have a MD 1.7 and it looks easy to convert to me, but I have to many 50mm lenses already. Maybe if I come accross a deal on a wide or portrait MD lens, I'll do one.
Dave
06-14-2008, 01:01 PM   #12
Otis Memorial Pentaxian
QuoteOriginally posted by xtriky Quote
Pentaxians,
Very impressive! Very impressive indeed!
What did you use for the K-mount?
06-23-2008, 11:49 AM   #13
I used a M42->P/K adapter, the one with flange similar to M42->EOS
k-mount, k10d, lenses, minolta, mount, pentax lens, slr lens
Konica, Minolta, etc. mount to Pentax K - How to save the old lenses vietlh81 Pentax Lens Articles 41 10-15-2018 08:51 AM
lens mount movement in k10d body kiwao Pentax DSLR Discussion 6 04-09-2010 08:15 AM
Advice Please: K-Mount body for Takumar Lenses david.elliott Pentax Film SLR Discussion 71 08-24-2009 10:32 AM
Is it possible to use K mount lenses with a 4/3 body? emr Pentax SLR Lens Discussion 3 05-05-2009 08:25 AM
Minolta MD lenses fitting on Pentax body? kuuan Pentax DSLR Discussion 1 02-10-2008 09:09 AM
All times are GMT -7. The time now is 07:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
