Here are some pics of the same set but then by Asahi. There are some differences, the inner diameter of the Kenko set is smaller and the mount which contacts the body is not anodized on the Asahi.
With manual lenses on this Asahi set it works flawless when you use the green button in M-mode for metering with any setting of the aperture ring before hitting the exposure button. You can actually see it quickly stop down to the preset aperture when you press the green button.
Since I don't know what is the effect of the anodized mount I cannot tell if it should be polished to bare metal for this mechanism to work. But you can try...
(I don't see the pics in the preview so here's the link to the album:
Twarp's Album: Gear - PentaxForums.com )
