01-10-2008, 04:14 AM   #1
wiseman's Avatar
Micro Screwdriver Types
I was wondering, what is the difference between a Phillips tip screwdriver and a JIS cross point screwdriver? Are the JIS types the correct tool to use on the small lens screws?
Iím going to try and repair my SMC F 70-210 lens. The focus mechanism gets jammed frequently. Otherwise it is a terrific lens!
p.s. I have read that some screws use thread locking compound. What is the best way to defeat the thread lock compound? I have read of using nail polish or heat (soldering iron). I would think either of those methods could damage plastic threads.
Thanks in advance for all your help
01-10-2008, 04:40 AM   #2
Lowell Goudge's Avatar
I have found that many screws are either put in with thread locking or effectively glued down with a small dab of paint or adhesive.
I have also found that many precision screw-drivers are made with brass tips or soft steel not hardened steel.
The best ones I have found are the cheap kits with chrome bodies and black shafts (usually hard but brittle) they last for a little while then shatter.
You might try snap on tools to see if they make a better quality one.
Also you might need a special tool to remove the large diameter rings, usially they have a notch on both sides for a tool, but I don't know what that is called
01-10-2008, 05:48 AM   #3
wiseman's Avatar
Thank you Lowell for your insight. I will be ordering a spanner wrench to remove the lens rings. How have you gotten around the thread lock compound?
01-10-2008, 01:31 PM   #4
I recommend this company for good quality precision tools.
https://www.micro-tools.com/
BobG
compound, jis, k-mount, lens, pentax lens, screwdriver, screws, slr lens, thread, types
RAW file types and differences... DaveHolmes Troubleshooting and Beginner Help 10 11-04-2010 02:02 PM
Need advice for types of filter!!! aLep Photographic Technique 11 06-14-2010 06:42 AM
Understanding lens types stcroixboy Pentax SLR Lens Discussion 7 10-05-2008 04:19 PM
Ever wonder about lens mount types? Big Dave Pentax SLR Lens Discussion 4 05-07-2008 10:25 PM
There are two types of Photographer Ed in GA Pentax SLR Lens Discussion 24 02-06-2007 08:17 PM
All times are GMT -7. The time now is 11:41 PM. | See also: NikonForums.com, part of our network of photo forums!
