Originally posted by spade111 Actually - Nikon did make a 13mm super wide lens - which was technically their most difficult to manufacture, and the most expensive lens in their catalogue (I think after inflation etc.) ever:
Nikon 13mm
That thing has virtually zero curvilinear distortion.... To reproduce that field of view on APS - we would need an ~8mm. Doesn't sigma make an 8-16mm or something these days?
As usual, Mr. Rockwell's review is full with approximations and inaccuracies. In fact, this 13mm Nikkor is far from being
Nikon's greatest lens. It has indeed a very low distortion on the edges of the frame, but it does distort in the center. It also exhibits plenty of chromatic aberrations and is not particularly sharp compared to modern superwides...
Originally posted by Ken Rockwell: The 13mm is Nikon's greatest lens. It is Nikon's greatest lens because not only is it big and supremely expensive, it is Nikon's, and perhaps photography's, greatest lens because it lets us make photographs we can make no other way.
There are bigger, rarer, more expensive, more unique and "greater" Nikon lenses. For example, the Nikkor 6/2.8 (5.2kg on the scale, 220° FOV), or the 1200-1700/5.6-8 (
only 15 ever made,16kg and a length of over 800mm)...
Here's the 13/5.6 with a D300:
Image Credit:
Ken Rockwell
Here's the 6/2.8 with a Nikon FM:
Picture Credit:
Dr Klaus Schmitt
And the 1200-1700/5.6-8 with a D3:
Picture Credit:
Mal Langsdon - Reuters Originally posted by Ken Rockwell: The Nikon 13mm is the world's widest non-distorting professional SLR lens ever made, by anyone, in any format.
And what about the Sigma 12-24/4.5-5.6 and the Voigtländer 12/5.6 -- this lens was initially designed for rangefinder cameras, but there is also a version in Nikon mount for Nikon SLRs? Not pro enough?
Originally posted by ="Ken Rockwell": Actual (Design) Focal Length:13.3mm. You're not being cheated; Nikon's 50mm lenses are really 51.6mm, for instance.
I don't really get the point: 51.6mm instead of 50mm is a 3.2% increase, while 13.3mm instead of 13mm is a 2.3% increase, not much of a difference!
Originally posted by Ken Rockwell: If you wish to make a printout for personal use, you are granted one-time permission only if you PayPal me $5.00 per printout or part thereof. Thank you!
No thanks!
Cheers!
Abbazz
