03-29-2012, 04:17 PM   #1
Docrwm's Avatar
Samyang 85/1.4 - couple of questions
I just got a Vivitar branded Samyang 85/1.4 used and am I overlooking it or is there no serial number on these lenses? Also, has anyone come up with a satisfactory replacement for the included hood? I usually use 3-stage rubber hoods but am wondering if anyone has found anything longer that works on this lens?
03-29-2012, 04:26 PM   #2
Lowell Goudge's Avatar
There is no serial number on samyang products
Ass for the hood, do you have an issue with flare, I have found the coatings on samyang products pretty good? Note the lens is a full frame lens so it would nautically have a hood for a 24x36 format
03-29-2012, 04:33 PM   #3
demp10's Avatar
I got a metal round hood from eBay that has 72mm male threads to attach to the lens and 77mm female threads on its front so it can take a 77mm lens cap securely. It's about 1 1/2 " long and now it is an integral part of the lens and works very well.
03-29-2012, 04:39 PM   #4
Docrwm's Avatar
QuoteOriginally posted by demp10 Quote
Thanks, a bit of an opening cone instead of a straight tube then. The lens cap is odd, doesn't want to fully engage the lens, and I'll probably replace it too.
03-29-2012, 04:41 PM   #5
Docrwm's Avatar
Thanks, its the only lens I've ever owned that doesn't have a serial number. As to the hood, no - I just use them on all my lenses for a variety of reasons and the one that came with the lens is a bit flimsy.
03-30-2012, 06:13 PM   #6
Docrwm's Avatar
The DoF is amazing with this lens. At f1.4 with a 10ft distance to the subject the DoF is something on the order of .2ft! In contrast the FA50 has a DoF under those conditions of .7ft. That's the difference between 2.4 inches and 8.4 inches at 10 feet - wow. Nailing focus with this lens is going to be a challenge.
03-30-2012, 09:57 PM   #7
QuoteOriginally posted by Docrwm Quote
But if you were going to take the same shot with a 50 then you'd also be standing closer. At 6 ft the DOF of the 50 is the same as that of the 85 at 10. Still is going to be tricky of course. Are you going to get a focus screen? Or are you going to do it with CIF or Live View?
03-31-2012, 05:44 AM   #8
Docrwm's Avatar
QuoteOriginally posted by kenafein Quote
Am going to use LV for the time being and play around with CIF.
03-31-2012, 07:41 AM   #9
In practical use, I replaced the OEM lens cap with a Tamron cap and left the lens hood off when I had this 85/1.4. I ended up trading it because of my frustration in focusing and because I wanted to focus closer. It is a great lens when you get everything in focus and have the right conditions. It was made for wide open shooting, and it's a fabulous lens.
03-31-2012, 04:45 PM - 1 Like   #10
joe.penn's Avatar
It is a great lens - but it is not just made for wide open shooting. I think this lens could even be more popular than what it is if we just don't buy into the "it's a 1.4 85mm so it must be just made for portraits" myth. This lens in my book is a great lens that can do waaaayyyyyy more than what people realize.
All of these were shot using CIF, with the exception of the last one as that is a FF film shot.
Vivitar 85mm 1.4 - f/4.5, 1250 ISO (It was getting dark, this was shot under artificial lighting)
(Note: I hope viewers realize the speed this subject is moving)
Vivitar 85mm 1.4 - f/2.5, 200 ISO (w/ ND8 filter attached)
Vivitar 85mm 1.4 - f/1.8, 3200 ISO
Vivitar 85mm 1.4 - f/8, 3200 ISO (Low Light)
Vivitar 85mm 1.4 - f3.2, 100 ISO
Vivitar 85mm 1.4 - (FILM SHOT) Super Program w/ 400CN B&W Film (scanned negative) - wanted to see how it would work on FF
03-31-2012, 05:04 PM   #11
Great shots Joe.
03-31-2012, 05:14 PM   #12
joe.penn's Avatar
Thanks Brent...
k-mount, pentax lens, samyang, slr lens
A Few Questions about Fisheyes, Samyang 8mm Damon Troubleshooting and Beginner Help 10 02-10-2012 07:13 AM
a couple of questions newtoallthis Troubleshooting and Beginner Help 5 12-15-2010 05:19 PM
Couple of questions jbander Pentax Medium Format 5 10-26-2010 06:28 AM
Misc A couple of weeks with Samyang 85mm f1.4 brkl Post Your Photos! 4 07-04-2010 09:38 AM
New K-x, couple of questions. Paleo Pete Troubleshooting and Beginner Help 15 06-09-2010 10:05 PM
All times are GMT -7. The time now is 09:54 PM. | See also: NikonForums.com, part of our network of photo forums!
