03-31-2012, 09:08 PM   #16
QuoteOriginally posted by A8YANG Quote
She performs Ballet on the stage. The distance is sometimes farand sometimes is closer, it all depends on the seat they assigned to me. Yes I want to use it for other purpose like traveling.My point is, I already got a Prime 55mm lens. Does it make sense to get a lens 50-135?or prime 200 is a good mix with my other existing lenses? Thanks
Most photogs have a lens collection with overlapping focal lengths, it's all about acquiring the best tools you can for the job... I don't see the problem with having both a 55mm lens and a 50-135.
03-31-2012, 09:29 PM   #17
Reportage's Avatar
QuoteOriginally posted by creampuff Quote
Are you sure you're a Pentax user?
Only a Canikon user would make such a glaring oversight.
There is absolutely no Tokina 50-135mm in Pentax mount in Shanghai or any other place on this planet.
Tokina never made such a lens for Pentax... ever.
And to add on, for some reason...there is no tokina 11-16mm f/2.8 for pentax mount. Sad really.
03-31-2012, 10:24 PM   #18
RioRico's Avatar
Well, there's a rather different Tokina version. My old M42 Sears-Tokina 55-135/3.5 was just US$8 shipped. The DA*50-135/2.8 costs 100x as much, so the Sears-Tokina is a fair deal. MF, but it works for me. I'll suggest that such a manual lens would be just fine for stage work, especially using CIF (catch-in-focus).
03-31-2012, 11:04 PM   #19
Brooke Meyer
Guest
Trying to keep dancers in frame is a challenge so you'll stay pretty active with zoom. Trying to zoom and manually focus would be really tough.
If you can trade seats so you are closer, something like a Tamron 28-75 will work well, especially for rehearsals. The Tamron 28-75 is a great all around lens, very good for portraits and near macro, very versatile. If you can attend dress rehearsals, they are gold, you can get close and move around, no audience to distract. When I can get on stage, I use my 12-24 a lot. So it all sort of depends.
I have four lenses, a 12-24, 28-75, 50-135 and 100-300. Rehearsals, I use 12-24 and 28-75. Performance, 50-135 and 100. The 50-135 is also a great portrait lens and optically, the best of the four.
Here are 3 recent from the Tamron.
PENTAX K-5  Photo
PENTAX K-5  Photo
PENTAX K-5  Photo
04-01-2012, 04:56 AM   #20
westmill's Avatar
Wow ! what an arogant prat you are
Im quite new to pentax actualy, I will pray for your
foregiveness at my glaring oversite.
I simply quoted a peice I saw on the internet, but its likely he was refering to the pentax variant.
I had not looked at Tokina lens for my K5 but I did assume they would make lenses for Pentax, especialy considering there connection. And yeah, I use nikon too.
I also corrected my oversite in my next post
04-01-2012, 05:41 AM   #21
Lowell Goudge's Avatar
I shot my daughters performances for years, dance, stage, plays etc. I used a 70-200/2.8 and only once in a very small auditorium, did I find that 70mm was too long. I had to sit in the lt row at that performance.
Consider the image size on sensor, and the simple formula
Image size = subject size x focal length / distance
04-01-2012, 09:34 AM   #22
littledrawe's Avatar
However, they did make a 60-120mm f2.8 MF lens that I just picked up a copy of. I would love to have a chance to photograph something like the ballet to test this lens out.
04-01-2012, 09:45 AM   #23
westmill's Avatar
QuoteOriginally posted by littledrawe Quote
I used to have one of those on a Minolta X700
Loved it
04-01-2012, 11:02 PM   #24
Hi Brooke Meyer: Thanks for sharing your photo. These are exactly what I want to shoot. How do you use your Zoom 12-24 lens because I found it very difficult to set the correct exposure for this lens, mainly due the lens is not fast enough (only f4) for indoor shooting and my K10D built-in flash light is not working well with this lens due to wide angle lens. Do you use a external flash light for these photos? How do you set the correct exposure for these indoor photos.
I already ordered the telephoto zoom 50-135mm lens. It cost me USD $849.99 from Amozon.com.
Thank you very much for all your suggestions.
04-01-2012, 11:23 PM   #25
Also, if you shoot indoor without the flash light, I guess you need a slower shutter speed and a tripod, but how do I shoot a photo of someone who is actively dancing without blurry effect.
Thank you in advance for any suggestions.
04-02-2012, 01:31 AM   #26
Frogfish's Avatar
You can't slow your shutter speed without flash if you don't want to blur the shot ! You need to keep your SS up anyway you can, by opening up the lens and/or by increasing your ISO.
04-02-2012, 12:34 PM   #27
Brooke Meyer
Guest
Flash is not allowed and is dangerous for the dancers. I use K-5s in manual mode. 95 % of the time, my settings are f4, 1/320 sec shutter and ISO 3200. Sometimes I got to ISO 6400 and 1/250. I upgraded from K20's for the high ISO capability. All my work is handheld except the 100-300 Sigma mounted loosely on my tripod ball head.
You can use your 50-135 at 2.8 and ISO 1600 with a K10 or K20. Try 1/250 or 1/320 shutter speed
04-02-2012, 12:50 PM   #28
eddie1960's Avatar
I shoot a fair number of events. for the type of event you are talking i think the50-135 is a no brainer, almost perfect. I shoot with 2 bodies at most events 1 with a 24-70 2.8 and the other with either a 14 or a 100 2.8depending on the venue, but I am in a photo pit for those. If I have to be back I would want the flexibility of the 50-135 (particularlyif I'm tied to one body since i don't like to change lenses if i can avoid it during the performance because that is when i always seem to miss a great shot
04-03-2012, 06:45 AM   #29
I thought about the same problem lately. The 50-135/2.8 should work fine if you can get close enough. Otherwise you can try a FA 80-200/2.8 to get more reach at the long end. The 200 prime only works if you really need as much reach as possible,
200mm, f2.8, k-mount, lense, mind, pentax lens, slr lens
Zoom vs Prime eccs19 Pentax SLR Lens Discussion 111 08-29-2011 02:53 PM
Short zoom or prime? Tomzee93 Pentax SLR Lens Discussion 15 11-25-2010 08:57 PM
prime vs. zoom a_brooke2006 Pentax SLR Lens Discussion 23 10-23-2010 01:59 PM
limited prime vs zoom trevorgrout Pentax SLR Lens Discussion 18 06-04-2010 01:01 PM
For Sale - Sold: Dremel fun: 4 lenses under $50. Vivitar 28-200mm, f/2.5 zoom, 135mm macro wallyb Sold Items 11 12-07-2009 11:18 PM
All times are GMT -7. The time now is 07:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
