Originally posted by GibbyTheMole Hi, RioRico...
I'm not concerned with exposure automation, and the lenses I will be using are standard MF lenses.
What I specifically need to know is: If I use these tubes, will I have to manually open up the lens to focus, and then manually stop it down to shooting aperture before pressing the shutter release to take the picture? If I'm taking a handheld closeup of a bug or something out "in the wild", it won't be practical to do that.
Maybe I'm wrong (which is why I'm asking) but it doesn't look like these cheap tubes have the lever on the rear required for the camera to stop the lens down from wide open to shooting aperture in the instant before the shutter fires, just like it does with a totally manual Pentax M lens.
On the other hand, all of the PK teleconverters I've seen have the aperture stop-down lever on the rear mount which is coupled to the aperture lever on the lens, so it should be possible to de-glass them and still have the auto stop-down function still work.
You are right in all the above. But you may not need to stop down after focus. As I understand it, you'll be using the tubes with a 100mm 3.5 lens. At 1:1 this is already a f:7.0 lens and any further increase in magnification due to tubes will increase the effective f-stop ( effective f-stop = f-stop(1+m)). Increasing the effective f-stop much above f:11 will soften images.
Here's an example of how a lens is usually removed from a TC: See the holes on the perimeter of the lens?
Stick the tips of a pair of scissors in them and turn - the lens assembly will come out. Like tihis-
If the TC is a macro-focus, "A type" like that shown above, removing the lens will convert it into an A type variable length extension tube (ie. with electrical & aperture control). This about the best one might expect for a macro extension device!
Regarding lenses stuck on tubes, all the times I've heard of (and experienced) were when the user hadn't figured out how to properly move the release button on the side of the tube (it varies from tube to tube). To be sure a lens won't get stuck, one could learn how to release the lens from the tube by mounting the camera end of the tube set to the lens end - figure out how to press the button on the tube to release the lens end.
It isn't yet clear to me what you are trying to accomplish; your initial post about the 3x focusingTC and 100mm 1:1 macro lens implied you are looking for quite high magnification; is that not true? I'm surprised you found the image quality satisfactory using the 3x TC - if it was, I'd hang on to that TC. How does it perform for far away subjects?
