There's a Canon 7D in our family, so I've tried using two different adapters.
The unchipped adapter makes you work in manual mode, and it meters pretty much fine with the exposure meter.
The chipped adapter gains focus confirm and communicates a focal length back as well as aperture, so you can use Av mode. It will throw the EXIF data off. By default, it shows a FL of either 50 or 55mm and aperture of 1 or 1.4. There is a way to program these by a complicated set of instructions which has no confirmation except when you finish it changes the FL and aperture on the picture. I'd set it to the focal length of lens and keep the aperture at the default value.
I've tried so far a couple of fifties (Rikenon 55/1.4, Super Takumar 50/1.4 and Super Takumar 55/1.8) on extension tubes and they seem to work pretty well. My advice to myself is that when in doubt, stop down one more stop than you think it needs.
