Originally posted by Big Dave I have a non-smc 17mm fish eye that I really like. On the K20 it is 120 degrees instead of 180 degrees. Used carefully it takes some great wide angle shots. The one limitation is that flare can be a problem in brite sun light due to the lack of smc coatings. I can't complain since I only payed about $50 for a mint lens. My solution is to fit a hood fashioned from a spray can cap. Due to the cropped sensor a hood can be used without vignetting. It seems to work well for me.
I have that lens too!!! I did some butchery to it, and attached a K adaptor to it permanently using the screw that normally holds the spring on as the jam screw. I cut a small notch in the mount to take the body lock pin. On ap-c, I expect a hood designed for a 24mm lens on 35mm would be a good size.
