04-07-2012, 08:30 PM   #1
macro extention for FA 77
hi guys
can you recommend a good macro extension for my FA 77 and any drawbacks using a extension rather than a dedicated macro.
thanks
04-07-2012, 09:45 PM   #2
Here it is what I did...
SMC Pentax 50mm 1/1.7 + 1 lens element from the other lens + ring from a filter...and some shots with this monster... :-)
PENTAX K20D  Photo
PENTAX K20D  Photo
PENTAX K20D  Photo
04-07-2012, 09:54 PM   #3
RioRico's Avatar
What you don't need: Extension tubes with autofocus linkage. AF isn't useful with macro (1:2 or greater magnification).
What you probably want: Extension with A-type connectors, to control the aperture from the camera, and to use pTTL flash.
What you may have to settle for: A-type teleconverters with the glass removed so they function as simple extension.
What you could get away with: M-type extension tubes or TCs, with a mechanical linkage to stop-down the aperture.
I just searched eBay for A-type macro tubes and I can't find anyone selling any. I haven't searched for M-type tubes or TCs because they're almost as limiting as ultra-cheap extension tubes (under US$10 per set, shipped worldwide from China). Your best option is probably to buy old A-type TCs and remove the glass. These might cost about US$30 each. They are usually about 25mm thick so you would need three of them to reach 1:1 magnification with your FA77Ltd.
Pros and cons: A 'dedicated' macro lens will be convenient, and expensive. A modern AF macro lens in the short-tele 90-105mm range can also be used for headshot portraits and general photography. Macro lenses are designed for edge-to-edge flatfield sharpness; the Limiteds aren't. Using extension with your FA77Ltd is economical, and the optics are fine as long as you DON'T need edge-to-edge flatfield sharpness.
If you want to work close without spending lots of money, consider a Raynox close-up optic to mount on the front of your lens. A true macro lens will perform better at edges; tubes will also be optically cleaner than a close-up adapter; but both macro lenses and extension reduce the light that reaches the camera. Close-up adapters don't eat light.
I'm a cheap bastard. See my article: https://www.pentaxforums.com/forums/pentax-lens-articles/152336-cheap-macro-b...lose-work.html
04-07-2012, 10:53 PM   #4
thanks for the info. but with a Raynox close-up optic how much of a maginification can i get. will it be 1:1. and how much of light will it eat away in terms of stops.and lastly what effect will it have with IQ of the image.and thanks for the link
04-07-2012, 11:25 PM - 1 Like   #5
RioRico's Avatar
QuoteOriginally posted by nirVaan Quote
1) How to calculate magnification from focal length and dioptre:
M = F*D/1000 -- where M is magnification, F is host lens focal length, and D is dioptre of the add-on lens.
The Raynox DCR-250 (stronger than the DCR-150) is +8dpt. We solve the formula as:
M = 77*8/1000 = 0.616x or 1:1.6 -- that's within macro range.
2) Front adapters like the Raynox don't eat light, and may even give a very slight boost. They also don't interfere with any other lens function, so you still have focus and aperture automation.
3) IQ using a Raynox, especially at image edges, isn't quite as good as with extension, but that may only be noticeable with close inspection, i.e. pixel-peeping. See the Raynox Club here for some absolutely brilliant images.
If 1:1.6 magnification isn't quite enough, then you can add extension. One de-glassed A-type TC that's 25mm thick should get you close to 1:1 when you use the DCR-250 also.
04-07-2012, 11:33 PM   #6
Plus one for the add-on lenses. Or what Vasyl did, since it's fundamentally the same, just a bit more adventurous. If you search ze bay you could get generic +2/4/6 etc add-ons, but they are usually not up to scratch, especially since you have the 77mm. The Raynox seem to be the icing of the lot, though.
I do have an "Apinar" close-up filter, the specs I have no idea of. It doesn't affect IQ that much.
You could also get an old manual lens for peanuts and reverse-mount it.
PS @Vasyl, which species of parrot is that feather from?
Last edited by Giklab; 04-08-2012 at 12:25 AM. Reason: spelling mistake&extra info
04-08-2012, 06:54 AM   #7
QuoteOriginally posted by Giklab Quote
The one similar to the Freelance Writer Files: It isn’t easy being a green parakeet mom. | Kansas City Freelance Writer Liz Craig
04-08-2012, 01:38 PM   #8
SRB Griturn has them, for only $250.or thereabouts (pizzas for a month?):
SLR Auto Extension Tubes
extension, fa, k-mount, macro, pentax lens, slr lens
VL Nokton 58 f/1.4 with extention tubes??? OrenMc Pentax SLR Lens Discussion 11 02-11-2011 03:35 PM
Extention Tube for Kx (and or) Macro Filter Marc Troubleshooting and Beginner Help 26 05-02-2010 07:20 PM
Rear converter and Extention Tubes robertdyne Troubleshooting and Beginner Help 2 04-06-2009 08:28 AM
Questions: using extention tubes? OrenMc Pentax Camera and Field Accessories 4 03-04-2009 05:35 PM
Auto extention tube? roentarre Pentax SLR Lens Discussion 15 02-04-2007 05:35 PM
All times are GMT -7. The time now is 12:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
