04-08-2012, 08:13 AM   #1
Belcik's Avatar
FA 43 limited got wet...
Hello,
Yesterday while shooting photos from car window, the photographer got nicely wet with spashed dirty water from the car going into opposite direction.
Everything was cleaned ASAP (including photographer), but i am still a little bit aftraid.
The water containted small particles of dirt - can the affect somehow mechanism?... also the stuff on the road is a little bit "greasy"
The water itself later was evaporated (if there was any) by means of warm air and silica inside of bags.
But... should I be afraid? - or not really?
04-08-2012, 08:29 AM   #2
It really depends on how much there was. While dirt and sand is a camera's worst enemy, it probably wouldn't end up inside anything because of the water. The only thing to do is wait and see if any issues arrise with the lens...
04-08-2012, 08:47 AM   #3
hcc
hcc's Avatar
As Adam indicated, the removal of any moisture is the most important by far. I would be much less worried about particles, especially considering the care taken to clean quickly the lens.
I had lenses completely wet and covered by mud. After an intiial and careful cleaning, the most important was to put away the lense and to dry it quickly. Prime lenses are typicaly much less sensitive to dirt than zoom lenses (the pumping action..).
Good luck with the lens but I would not be too worried since you already took good care of the gear...
04-08-2012, 09:33 PM   #4
mikeSF's Avatar
not really
04-09-2012, 04:37 AM   #5
axl
I used one of my 43s in snow and rain and it was perfectly ok. To be sure, I'd advise you to lock it in airtight container with some silica gel and leave it for a day or so, which you did so you should be fine.
04-12-2012, 01:23 PM   #6
Ash
Community Manager
Ash's Avatar
Just keep shooting with it and observe its performance. It might surprise you that everything about the lens is still alright.
bit, car, k-mount, pentax lens, photographer, slr lens, water
For Sale - Sold: K-5 + 18-55 + Batt Grip/3 batts, 31mm Limited, 15mm Limited, 70mm Limited Sperdynamite Sold Items 7 02-24-2012 12:07 AM
Nature Let's Get Wet Bob Harris Post Your Photos! 14 06-26-2011 10:25 AM
Wet in the UK View Welcomes and Introductions 5 09-18-2010 10:06 AM
Machinery Wet redeleon Post Your Photos! 4 09-07-2010 05:39 AM
DA 40mm limited in the wet? CWyatt Pentax SLR Lens Discussion 2 01-11-2010 02:47 AM
All times are GMT -7. The time now is 12:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
