04-09-2012, 10:57 PM   #1
littledrawe's Avatar
Modifying this lens to fit pentax
This is the pentax k mount but presumably for ricoh based on the "R" in the engraving on the lens mount. It won't mount on my camera and I am wondering if it is the aperture lever shield that is blocking it from sitting flush on the camera mount? Can I cut this off maybe to the same shape as my DA 18-55 WR or some of my lenses don't have the aperture shield at all?
Then there is the ricoh pin, is that the Gold spot seen in between the contacts? This is my first ricoh experience so is the pin recessed normally then comes out when mounted on the camera or is this one of the ones that is not a promblem because it is not protruding?
here is a link to the lens with pictures hopefully it works easier than taking pics and uploading them myself:
TOKINA 28MM F2.8 MANUAL FOCUS LENS IN PENTAX K-AR MOUNT,/146587 | eBay
04-10-2012, 01:46 AM   #2
RioRico's Avatar
That is indeed a vastly-oversized lever guard. See if it's held on by 2 or 3 little screws. If so, just remove it, and save the parts in case you ever want to resell the lens. Otherwise you can trim it down.
04-10-2012, 06:50 PM   #3
Thanks RioRico, it came off and I took the ricoh pin out too. I've heard it was easy enough but never encountered it til now.
I followed this guide to get the pin out;
theatre of noise: Ricoh Lenses On Pentax Cameras -- The Ricoh Pin Fix
I found the link deep in the list of threads it pulled up so putting it here again to get it closer to the top for other noobs like myself to see
aperture, camera, k-mount, lens, pentax, pentax lens, pin, ricoh, shield, slr lens
Will Tokina lens fit Pentax KR camera? Pauline Tate Troubleshooting and Beginner Help 11 03-23-2011 04:48 PM
Modifying a Pentax lens SimonMW Pentax SLR Lens Discussion 10 12-13-2010 05:26 PM
Will this lens fit Pentax K-x newyorker Pentax DSLR Discussion 26 10-04-2010 01:23 PM
Is there any lens faster than F1.2 that will fit a Pentax? Christopher M.W.T Pentax SLR Lens Discussion 29 09-30-2010 12:20 AM
Modifying C/Y mount to fit Pentax K; hard, easy? excanonfd Non-Pentax Cameras: Canon, Nikon, etc. 2 01-20-2010 09:35 PM
All times are GMT -7. The time now is 11:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
