04-12-2012, 09:50 PM   #1
DXOMark results I don't understand
Hi guys,
Maybe someone can enlighten me. Because I for one can't understand this:
The DA 35mm F2.4 AL is considerably better than the DA 40mm F2.8 Limited.
So is there a mistake. And if so, where is it and what is it?
04-12-2012, 10:31 PM   #2
basically, it wins out cause its faster.
04-12-2012, 10:34 PM   #3
From what I see, DA 40 has better light transmission, better distortion, and better CA so it is a better lens.
04-13-2012, 02:18 AM   #4
drougge's Avatar
QuoteOriginally posted by Doanh Quote
Really? The numbers aren't high enough resolution to say as far as I can tell. 2.6 is about a quarter stop from 2.4, 3.1 is about a quarter stop from 2.8. In absolute numbers the DA 35 obviously wins, which I assume is how it got the higher summary score. Or maybe they score for some subjective usefulness of focal length thing?
04-13-2012, 04:05 AM   #5
JinDesu's Avatar
I questioned how DXO scores too:
QuoteOriginally posted by JinDesu Quote
Lens score should be considered with the testing platform (camera). The top lenses scoring 30-34 are on full frame cameras. All their lenses appear to get a +10 or +12 factor when shown on a full frame. If you take the lenses tested on the D3x and drop to the D7000, you'll get a -12 to the score, putting it closer to what the Pentax lenses are scored at.
Now, that being said - the top scoring Pentax lens is the DA 35 F2.4 on the k-5. It outscored (at 15, so full frame would be 27-28):
DA 70mm Limited
DFA 100mm WR
DFA 50mm F2.8
DA 40mm Limited
Just a quick comparo of the 35 F2.4 and the 100 WR, both reached 46lpmm, the 100 WR has 0% distortion vs 3% on the 35mm, the 100 WR has 0.5ev less vignetting than the 35 F2.4, and it's chromatic abberations are 3 micrometers smaller.
The only thing the 35 F2.4 has on the 100WR is light transmission, which seems to be at .6Tstops better. Now, the general mark of the Limited lenses are the lower light transmission, and it seems to be the big factor in the DXO score. In fact, the 40mm F2.8 is also 46lpmm, 2% distortion, same vignetting, and less chromatic aberrations, but lower light transmission and it scores 4 points lower than the 35 F2.4.
It's weird.
It does seem that light transmission is a big factor for them - which is unfair towards Pentax Limited lenses.
04-13-2012, 04:44 AM   #6
causey's Avatar
Yes, their final score heavily relies on the light transmission (just look at how unfair this score is towards the very good 55-300), but neglects other factors, which may not even be taken up in a calculation, such as micro-contrast. The DxO score has little to do with how pics taken with a certain lens look.
04-13-2012, 04:52 AM   #7
macTak's Avatar
I too really don't like how DXOMark rates lenses. The only thing of any value in their lens tests are their MTF graphs, in my opinion.
04-14-2012, 09:54 AM   #8
The DA35/2.4 is a good lens, especially at the center of the image. The DA40 has better resolution off-axis, and is what I would choose for landscape work, that is, if it had a depth of field scale.
da, k-mount, pentax lens, slr lens
don't understand how to read lenses safc Troubleshooting and Beginner Help 11 09-27-2011 10:05 PM
I don't understand why stop down metering doesn't work well at higher f stops. geekette Pentax DSLR Discussion 51 06-08-2011 10:39 PM
I don't understand photozone.de justtakingpics Pentax SLR Lens Discussion 15 04-16-2011 12:20 PM
still don't understand stop down metering dh4412 Troubleshooting and Beginner Help 5 03-17-2011 05:43 AM
K20d - I don't understand auto ISO Rev Andy Pentax DSLR Discussion 16 04-16-2010 05:09 PM
All times are GMT -7. The time now is 02:54 AM. | See also: NikonForums.com, part of our network of photo forums!
