See my signature, I would go batshit crazy if I had to fight with a K or M lens and green button everything instead of just using the front and rear dials for aperture and shutter speed, especially since the K20D (and I think your samsung) has a beak sticking out that makes it basically 100% impossible to operate the aperture ring since you cant easily read it or even get a good grip on it, keep that in mind.
With the 3 higher end reasonably fast zooms I have, I have the full range from 24-210. the 35-105 has a real macro setting at all focal lengths (not just close focus) and at can focus from something like 4" at 35mm to 24" at 105mm. Each was purchased in like new condition for well less than $200 shipped off of ebay.
A series primes are really only necessary for speed, I would like to add a 28mm f2 to this lineup since I want a faster lens in a wider range than the 50mm 1.4 for low light work.
Though this setup is perfect for FF it would do better with a bit wider low ends for APSC, but I make do, and I ended up buying the 70-300 cheapo tamron used for less than $100 because often 210mm just isn't enough.
