Originally posted by NaClH2O
RioRico that's what I'm doing with the low profile one I have now. But it's a pita. I'll try jatrax's method. It seems a lot easier than holding the shutter button half way with one hand, turning the filter ring with the other and trying to keep the camera steady and pointed exactly to the same spot. I know it can be done, I do it, but it's still a pita.
Oh, I don't recalibrate for every shot! I usually find the max-polarization position and leave it there. Exceptions:
1) I most commonly use CPLs on very fast non-A-type lenses like the Vivitar-Kiron 24/2 (with iris blades stuck wide open) or my K50/1.2. I'll in sunshine with with CPL on, adjusted so my K20D's shutter stays below the flashing 1/4000 second warning. If I go into lesser light I either switch to minimum polarization or just remove the CPL.
2) With a CPL on slower lenses, I only adjust polarization to accommodate the shutter.
