01-13-2008, 08:55 AM   #1
FA 50mm f/1.4 autofocus
Is this a good lens for the K10D camera? I am looking for a good lens for some portraits and for shooting sports in a gym.
01-13-2008, 09:20 AM   #2
blende8's Avatar
Yes, it's a very good lens.
Well suited for your purposes.
01-13-2008, 09:22 AM   #3
Thank you so much for taking the time to reply. I am off to order it right now!
01-13-2008, 09:25 AM   #4
One more thing. Is the Tiffen 49mm uv protector glass filter a good filter for this lens? I am nervous buying things on line. I like to make sure everything works before I buy it. So I am hoping for a little from my Pentax forum friends so I can give this on-line thing a try.
01-13-2008, 10:01 AM   #5
ahilgaz's Avatar
Yes, you can order the tiffen filter. Tiffen is a good brand for filters, there is also Hoya with similar quality. And also B+W which is the more expensive and supposed to be better.
For lenses I will also recommend you the FA 35mm f/2 lens which is only 1 stop slower but gives you a wider angle POV
01-13-2008, 11:16 AM   #6
TheWengler's Avatar
QuoteOriginally posted by ahilgaz Quote
They want portraits and indoor sports. To me wider doesn't seem to be the way to go.
The 50mm lens will work great for portraits. That's what I use it for my self. For indoor sports it seems like you might want something a little longer. It all depends on where you'll be shooting from. If you do need something longer then take a look at the 70mm f/2.4.
fa 50mm f/1.4, k-mount, lens, pentax lens, slr lens
FA 50mm F1.4 AutoFocus problem vizjerei Pentax SLR Lens Discussion 2 11-09-2007 09:29 AM
SMCP FA 50mm F1.4 autofocus or not? Chilichoco Pentax SLR Lens Discussion 1 06-12-2007 01:50 AM
autofocus 50mm f1.7 or below Toonahfish Pentax SLR Lens Discussion 5 03-28-2007 08:00 PM
All times are GMT -7. The time now is 02:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
