04-17-2012, 05:05 PM   #1
MSL's Avatar
Adaptall 2 lenses - worth keeping a PKA adapter?
I recently acquired an Adaptall PKA adapter as part of a larger kit. It also came with a 58A 70-210/4-5.6 lens. It is amazing how much smaller and lighter this lens is compared to my SMC-A 70-210/4. I'm hoping to get the time to compare the two, although it isn't a focal range I use often at the moment. First I have to fix the adapter using the handy dandy instructions I know are posted on this site.
I'm debating whether to keep the adapter or not, as I know they are are to find. But before I rush off to sell it, I'm wondering if there are any interesting or top-notch adaptall lenses I should look into. The 90 and 180 (macro) primes look good, but they aren't that cheap and I might do just as well with an AF macro or Pentax macro instead.
I know I can trawl the lens database, but for most of the listed lenses there aren't more than 1 or 2 reviews, and so there is no solid basis for comparing one lens to the next because the reviews are quite subjective. So I'm throwing it to the group - any lenses I should hunt for, or should I just give a pass to the adaptall system as right now I don't have any other camera bodies, and aside from buying a K200/K20/K-x as a backup/teaching camera, I wasn't planning on buying one.
Thanks,
Marc
ps. if it helps, I have lenses that cover 28, 50, 55, 18-55, 35-105, 70-210, but I wouldn't let this affect the suggestions you make
04-17-2012, 06:20 PM   #2
sholtzma's Avatar
It might help to know more. What is your budget like? What kinds of lenses do you like? What do you tend to shoot?
For example, I owned the 90mm MF macro (with the adapter for 1/1) for years. Loved the lens. It was light, well built, inexpensive, and had great IQ. It allowed me some fine macro work, but I grew to want more distance from my subjects and now have a Sigma 180mm AF macro. I also tried the 300mm f2.8 but didn't like the copy I had, and it turned out not to be enough reach (I once owned Bigma).
04-17-2012, 06:27 PM   #3
Blue's Avatar
QuoteOriginally posted by MSL Quote
Thanks,
Marc
If you are going to use adapall-2 and SP, then the PKA is worth having because it will allow A type operation. As far as the SP 180/2.5, it is one of my favorite lenses and I have a PK/A on it. However, there were only 3000 of them ever made spread out among users all platforms. They do come up a few times a year.
04-17-2012, 06:43 PM   #4
MSL
MSL's Avatar
QuoteOriginally posted by sholtzma Quote
One reason that I kept this vague is because I'm wide open to suggestions. I started with the 18-55 WR lens, and this was back in January. Since then I've bought a bunch more, and mostly manual focus. The vast majority of the photos I've taken the past few days have been with extension tubes and green button metering. So I run from fully manual to almost fully auto (I'll operate in Av or TAv modes when using AF lenses most of the time). The only common theme I have is that the lenses have been cheap - typically under $100, and as low as $10-25 at times.
Good to know how few of these lenses there are. I missed buying a either a 90 or 180 / 2.8 (pretty sure it was a 90 if I recall right), which I believe does 1:1 macro rather than the 1:2 of the 90/2.5, but I've since read that this occurs because of some unusual internal optics. But it is this sort of insider information on the more desirable lenses I'm looking for before I decide whether to spend time looking for adaptall lenses or not.
04-17-2012, 07:18 PM   #5
Steinback's Avatar
The SP 60-300mm f/3.8-5.4 (23A) is probably the next best thing to the DA 55-300. I have seen several sell for around $40 without a mount. There are several other adaptall lenses that are recommended regularly in the Adaptall Club thread.
04-17-2012, 08:56 PM   #6
pacerr's Avatar
Read the Lens Club > Adaptall forum for some insight into the pleasures an tribulations of the Adaptall lenses. Some definitive reviews in the Review section too.
https://www.pentaxforums.com/forums/lens-clubs/59769-adaptall-mount-club-tamron.html
If you can stand not having auto-focus (or AF complaints!) you'll find some excellent, and affordable, lenses in the Adaptall-2 SP line.
They're not for everyone, especially the rapid-fire folks, but it's hard to find optically equivalent, modern lenses for 3-4 times the cost. A PK/A adapter is not absolutely necessary if you're comfortable with manual modes, but definitely a convenience.
If you enjoy photography for the pleasure of the gear as well as excellent results and a personal challenge you'll enjoy the Adaptall lenses but they do require attention to detail.
H2
04-17-2012, 08:57 PM   #7
WWIFA's Avatar
I will second the SP 60-300(23A). For the prices it can be bought for, $40-60US, it is a ridiculous bargain.
Wonderfully sharp, nice colors and rendering and a melty bokeh. I've noticed no difference in sharpness between 60mm and 300mm. F8 on gives the best edge to edge crispness. I kept this on my camera for three months this winter and I bet it would have been fun with the PKA mount. I really enjoyed the versatility in range and the macro function which does 1:1.55, although you're getting quite close to things with the front element at that point. I set the SR to 300mm and never changed it and it worked fine. Keeping the shutter speed at least 1/320s gave me good results handheld. It is a good chunk of lens to carry around all the time, though.
All in all, one of my favorites. Hope that helps you. The 90mm macro is also supposed to be a gem. The https://www.pentaxforums.com/forums/lens-clubs/59769-adaptall-mount-club-tamron.html I think would offer up more examples, replies.
Bruce
04-17-2012, 09:51 PM   #8
Nick Siebers's Avatar
The 70-210 f/3.5 constant aperture is pretty good, too. But the 90/2.5 macro is the best of the adaptall lenses I have used.
04-18-2012, 03:16 AM   #9
Abbazz's Avatar
Tamron Adaptall 135/2.5
My personal suggestion would be the 135/2.5 lens (03B). People often overlook this lens, because it seems there's nothing really special about it. But I think it has many advantages over similar lenses from other makers:
- It's fast for a 135mm. F/2.5 is only 1/3 stop faster than F/2.8, but it's enough to make the image appear brighter in the finder. And it also allows better background blurring.
- It's reasonably compact and light for a fast telephoto (less bulky than the Pentax 135/2.5). No problem to carry it all day long in a small pouch, just in case...
- Thanks to the use of a high refractive index glass element, it delivers remarkable image quality, right from wide open, with good sharpness and extremely low radial chromatic aberration. There's a bit of longitudinal chromatic aberration, but it's always the case with fast non-apo telephotos.
- It has a very handy built-in retractable lenshood.
- Its bokeh is creamy soft, with no trace of bright rings.
- It focuses relatively close for a 135mm prime lens (1.2m), offering a magnification of 1:7 without any accessory.
- It is well built, and the focusing action is remarquably smooth.
- Last but not least, since it's a little known lens, it can be bought for a song!
I like to carry mine when I need a fast telephoto but don't want to lug around a 70-210/2.8 brick. It's remarkably versatile and I warmly recommend it.
Cheers!
Abbazz
04-18-2012, 03:55 AM   #10
Lowell Goudge's Avatar
I have 2 PKA adaptors but 3 lenses, not that I want another adaptor, as I use one lens with an M42 mount, but there are some fine Tamron lenses out there and to get caught without an adaptor is a PITA. My latest lens is the 200-500/5.6 which came with a PKA plus 2 Nikon adaptors. It would not have changed my decision to purchase the lens without having a PKA adaptor for it, but I would not have wanted to waste time searching for one if I didn't have it. You never know when you will find a rare lens , and you need to be ready to get it when you do find it. That's my $0.02
adaptall, adaptall 2 lenses, adapter, camera, k-mount, lens, lenses, macro, pentax lens, pka, reviews, slr lens
For Sale - Sold: Tamron Adaptall 2 PK/A PKA mount adapter. jjdgti Sold Items 3 12-20-2010 08:02 AM
Are these three lenses worth keeping for a Pentax KM? Stefan Carey Pentax SLR Lens Discussion 16 11-15-2008 01:58 AM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
