04-18-2012, 09:23 AM   #1
userage's Avatar
Help with Helios, will it get stuck?
So my Helios just arrived and just before mounting it I noticed it has an aperture pin. I read somewhere that this may get my lens stuck once mounted, is this true? Do I need to remove it or superglue it down. Its a Helios 44m so it has the A/M switch so gluing it down and just sticking to M should be fine right?
PENTAX K-x  Photo
04-18-2012, 09:30 AM   #2
pezmaker's Avatar
Good on you for paying attention, but this isn't the "dreaded Ricoh pin" that you're thinking of, it's just the m42 aperture pin. Your lens has an A/M switch, so focus in A, meter and shoot in M. That pin will not cause anything to stick anywhere.
--- EDIT ---
Also note - the m42-k adapter on that lens is the full flange type - it'll allow you CIF (Catch In Focus), but it won't allow infinity focus.
04-18-2012, 09:34 AM   #3
userage's Avatar
QuoteOriginally posted by pezmaker Quote
--- EDIT ---
Cool thanks for a quick reply
Also yeah I know about the adapter, I think I'll be okay with it though for now, I don't plan on using this lens to focus to infinity much anyway. (x
04-18-2012, 09:48 AM   #4
Philoslothical's Avatar
Just to confirm, all "auto" m42 lenses have this pin, and it has absolutely not effect on a DSLR. The pin retracts if it pushes up on anything, but I think it's just open air behind it when mounted.
04-18-2012, 09:58 AM   #5
boriscleto's Avatar
QuoteOriginally posted by Philoslothical Quote
There is nothing for the pin to push against unless you buy an expensive adapter that has an extra rim.
04-18-2012, 06:21 PM   #6
RioRico's Avatar
Use your Helios in good health! I have exactly the same setup: Helios-44 with cheap safe wide-flange no-infinity-focus M42-PK adapter. It's great for portraits or any work closer than about 10ft / 3m. As mentioned, the M42-auto aperture pin won't get stuck on anything. Don't glue it down because: 1) it's harmless; 2) gluing lowers resale value; 3) gluing isn't not necessary -- the lens has an M/A switch already. Cheers!
04-18-2012, 07:46 PM   #7
hcarvalhoalves's Avatar
I have modded mine (non preset) by opening it and adding a shim to keep the pin down. So it's easily reversible if I ever sell it, although I doubt
04-18-2012, 08:12 PM   #8
RickyFromVegas's Avatar
I simply opened up my 44m and removed the pin.
Why? Because at one point I believed that the pin was scratching the 2 bronze contacts inside the mount.
It wasn't, but either way, I was relieved after doing so, and I got to learn about 44m's construction.
helios, k-mount, pentax lens, slr lens
Sibling Rivalry: Helios 44M vs. Helios 44M-4 stevebrot Pentax SLR Lens Discussion 36 08-03-2013 09:31 AM
PK-M 50/1.4 ring stuck, back-plate screws stuck fungiman_md Troubleshooting and Beginner Help 4 05-10-2011 12:54 AM
People 'O Helios O' Helios where art be? JohnBee Post Your Photos! 6 03-12-2011 07:19 PM
For Sale - Sold: M42 Helios 44M-6 MC 58mm F/2 & Helios 44-2 58mm F/2 donTTouchonlywatch Sold Items 6 12-25-2009 02:16 AM
All times are GMT -7. The time now is 07:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
