01-13-2008, 03:13 PM   #1
Need Adapter help for macro lens :)
I just won a Tamron 90mm f2.5 Macro SP Adaptall 2 lens in an auction. I read really good reviews on it, I know it's 1:2 while the newer f2.8 version is 1:1. So I need help with 2 things.
1. What adapter/adapters do I need to get this lens to fit on my K10D
2. What Tubes do I need to get this lens @ 1:1
Thanks in advance, OZ
01-13-2008, 05:23 PM   #2
roy
roy's Avatar
keep your eye on ebay. the ET for this lens shows up quite a bit without the lens..
you'll also need an adaptall PK or PKA mount. the PK mount will work fine but you'll need to use it manually..
01-13-2008, 05:36 PM   #3
rvannatta's Avatar
QuoteOriginally posted by DarkSideofOZ Quote
tradidtionally the extension tubes have been sold in a set of 3. The set I have consists of a 12mm, a 20mm, and a 36mm tube. (I have a Kenko set). They can be used individually or stacked. This gives you choices depending on how far you want to go. You will also occasionally see a bellows system on EBAY. On some of the camera bodies they don't fit well, no because of the lens mount but because there isn't external clearance. The addition of a short tube on the back of the bellows solves the clearence issue.
the real problem with macro photograhy on the K10 that I have not resolved is the fact that the K10 won't support the Pentax ring lights, and available light macro photography is a real problem because you light goes away along with your depth of field as you 'get closer'.
01-13-2008, 05:40 PM   #4
selar's Avatar
Look at ebay item number 260201344743 - this is the exact adapter you need to make this lens function as a A series lens (auto aperture). Auto aperture also gives you the ability to use P-TTL flash, rather important in macro photography.
There is also a K version of this adapter, without the advantages of the A series adapter.
The A version should have P/KA clearly stamped on the adapter. It should also have electrical contacts - The P/K version does not have one.
This lens can also be used on other SLRs with the appropriate Adaptall - 2 mount.
k-mount, lens, macro, macro lens, pentax lens, slr lens
For Sale - Sold: NEW Tamron 90mm F/2.5 Adaptall-2 Macro Lens with NIB 1:1 adapter and used PK m Nick Siebers Sold Items 13 12-20-2008 11:23 AM
For Sale - Sold: Phoenix 100mm Macro lens w/1:1 adapter Panache Sold Items 8 10-14-2008 09:11 AM
For Sale - Sold: K10D, DA 35mm Macro, 2x Macro, 360FGZ Flash, 70-210mm f4, m42 adapter and lens drivel Sold Items 19 08-19-2008 04:53 PM
For Sale - Sold: FS: Vivitar 100mm f3.5 Dedicated Macro PK-A Lens with 1:1 Matching Adapter Youngster Sold Items 2 03-10-2008 08:36 AM
Phoenix, 100mm f/3.5 Macro lens with 1:1 Adapter racinsince55 Pentax SLR Lens Discussion 3 12-11-2007 03:24 AM
All times are GMT -7. The time now is 12:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
