Originally posted by newarts That's correct - the lens does not report the f-stop or its range. Preset means you close the aperture to the setting you desire and it closes to that value right away, before focusing (although some focus wide open then change f-stop to shoot.). I do not find this to be a problem as I seldom use f-stops higher than f:5.6.
In camera metering works fine with the green button
I made an easy, reversible modification of my camera's mount so it thinks all lenses are "A" type. This lets P-TTL flash work properly with all lenses and allows me to set the proper lens f-number to be recorded in EXIF (adjusting the viewfinder's report of f-number has no effect on an m42 lens). I have found no downside to this mod.
Dave
I just want to clarify exactly the advantages this gets you. Do you still need to set the desired aperture on the lens, or will the camera stop if down properly if you leave the aperture on maximum?
So if I am shooting with my M50 f1.7 on my K5 in Av mode, I would leave the lens set at f1.7, set the camera to f8, and the camera will stop the lens down as if it were an 'A' lens?
Or set the lens to f8, and the camera to f8 too to get the correct shutter speed?
Cheers,
Jez
Edit - Ah, or do I leave it set at f22?
