04-19-2012, 06:50 PM   #1
Docrwm's Avatar
70 Limited Lens Cap question
I've got a 70 Limited incoming (used ) and it is sans cap. Are there any suitable alternatives to the $30 cap offered by Pentax?
04-19-2012, 07:11 PM   #2
crewl1's Avatar
NOt sure but the outside diameter of the lens where the cap slips on is 45mm.
When I measure the inside of the cap it is 46mm when pressing hard but it has flocking so that provides the hold.
Maybe a 45mm plastic or rubber cap of some sort would work?
04-19-2012, 07:20 PM   #3
Get the original, it is very nice. I would buy one for 30 in a second if I lost mine.
04-19-2012, 07:24 PM   #4
Docrwm's Avatar
QuoteOriginally posted by kenafein Quote
Trying to avoid buying new Pentax branded items right now. I have found it for less than MSRP though
04-19-2012, 07:26 PM   #5
Docrwm's Avatar
QuoteOriginally posted by crewl1 Quote
Thanks for the #s, I'll probably try an inexpensive plastic one as you suggested until later.
04-19-2012, 07:29 PM   #6
Ok, a 49mm cap works if you take off the hood. Good luck.
04-19-2012, 07:35 PM   #7
Docrwm's Avatar
Gracias!
04-19-2012, 07:47 PM   #8
Nick Siebers's Avatar
I used for a while a 49-->28mm step down ring and a 28mm pinch cap for a DA40 style hood. On close testing it did vignette just a little wide open; but it is an inexpensive and compact solution.
04-19-2012, 07:52 PM   #9
Docrwm's Avatar
QuoteOriginally posted by Nick Siebers Quote
I love the crativity and generous sharing here at PFs, thanks!
cap, k-mount, lens cap, pentax lens, slr lens
43mm Limited Black Metal Lens Cap drolph Ask B&H Photo! 4 08-23-2011 10:01 AM
Alternative lens cap for the 70mm f/2.4 limited? jms698 Pentax SLR Lens Discussion 2 12-08-2010 05:43 PM
Lens cap for DA 40mm 2.8 Limited ? tokyoso Pentax SLR Lens Discussion 7 01-30-2010 07:03 PM
odd lens cap on the Pentax DA 40 f/2.8 limited WMBP Pentax SLR Lens Discussion 22 10-20-2009 11:24 PM
All times are GMT -7. The time now is 08:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
