04-20-2012, 04:55 AM   #1
Which lens for levitation photography
Hi,
I'm a beginner and I will receive my first DSLR in a few days (K-r + 18-55 Kit)
My point is to learn different aspects of photography, and one of the first project I would like to do is "levitation photography"
I've been inspired by the blog of one asian photographer, who's work has been discussed in this thread
But I'm wondering what kind of lens(es) I should buy and use for this kind of photography.
I'm on a low budget, around 300-400 , and cheaper would be even better.
Any advices ?
04-20-2012, 05:31 AM   #2
Anvh's Avatar
You can use any lens you want, just depends on what kind of view you want.
04-20-2012, 06:15 AM   #3
Digitalis's Avatar
anything - as long as it is f/2 or faster, especially for indoors.
04-20-2012, 08:37 AM   #4
I don't find so many lenses at F2 or faster, especially in my price range.
(Most of them are F2.4 or even F2.8)
Which one should I choose between this two ?
- Pentax 50mm 1.4 smc FA
or
- Samyang 85mm f/1.4 IF MC Aspherical
04-20-2012, 08:49 AM   #5
Actually, I'm pretty sure you could use the DA 35mm f2.4. You just need to get the shutter speed fast enough. I didn't read the article so I'm not exactly sure how she achieved the stop action, but I'm fairly certain you could go with that one. Besides, it is a very good lens in it's own right. I own both it and the MUCH more expensive FA 35mm f2.0 and I like the DA a lot better. Your other option is to rent a FA 43mm ltd, that would certainly work.
NaCl(hope that helps)H2O
04-20-2012, 08:54 AM   #6
QuoteOriginally posted by Jilune Quote
or
It's a point of view thing. Your minimum shutter time won't really change much between those two lenses.
That said I'd probably say the 50 mm would be better - the 85mm would mean you'd probably end up walking further away from the camera.
If you're doing it outdoors you don't need the 1.4, but the 1.4 will allow you more control over what's in focus and out of focus.
04-20-2012, 08:55 AM   #7
If you boost the ISO a bit, f/2 isn't necessary, you can get away with f/2.8, even slower outside.
I hope you are in good shape, because you will be getting a lot of exercise!
Hard to choose between the 2 lenses you mention, because the FOV is so different.
If you work this project outdoors, the kit 18-55 will be good enough until you decide on which focal length(s) are best for you, then you'll know how to best spend you money on your next lens.
04-20-2012, 09:52 AM   #8
RioRico's Avatar
Use the kit lens and onboard flash. Get a tripod. No fancy|fast lens is needed. For further-distant shots, get a stronger flash, but your onboard flash will be fine if you shoot in the 18-30mm range.
The advice for faster lenses is good; I go nowhere without my FA50/1.4, my gotta-get-the-shot lens. It's great for action, low-light, and DOF.control / image.isolation. But you can get your jump shots with what you have. Flash solves the low-light and action problems, and the slowness of the kit.lens solves the too-thin-DOF problem. Have fun!
04-20-2012, 10:32 AM   #9
Anvh's Avatar
Depends on the amount of light and you could always use a flash
04-20-2012, 02:38 PM   #10
Do not use the 50mm f/1.4 or the Samyang 85mm.
Use either the kit lens or something like the DA 16-45mm f/4, which should be in your price range.
From my experience, you are going to be shooting at the wide end of these lenses. What makes levitation photography interesting is the background and context. That's why I don't use a huge aperture either. I don't want to blur the background out.
I assume you are going to make the model "levitate" in post-processing, not by jumping or something. That's why you don't need a fast lens to freeze the action.
04-20-2012, 02:49 PM   #11
QuoteOriginally posted by Shamwow Quote
I think you've completely missed the objective, there's no PP involved, best to look at the thread cited in the OP.
04-20-2012, 03:31 PM   #12
QuoteOriginally posted by luftfluss Quote
You are right, I did miss the objective.
If you want to simulate levitation by jumping, I think you need a fast lens.
If you want to do it through post-processing, you have many more options.
04-20-2012, 05:36 PM   #13
RickyFromVegas's Avatar
Consider sigma 30mm 1.4
That lens is quite exceptional at rendering '3D' effect for its subject, it'll help with the levitation illusion better than most.
Look up images taken with that lens on this board.
04-20-2012, 06:10 PM   #14
Digitalis's Avatar
you could just get a 50mm f/1.4 Takumar - faster than f/2 and they are simply brilliant lenses considering their low cost these days.
04-23-2012, 01:02 AM   #15
Thank you so much everybody for all your advices.
There is so many different possibilities that I'm quite confused now.
I guess a smart idea would be first to try with my kit 18-55, so I can find out which focal length I prefer.
Then I'll look for the fastest lens for this focal length, in my budget.
My K-r will arrive thursday morning ..... I can't wait anymore, I'm thinking about it all the time
k-mount, pentax lens, photography, slr lens
Lens for Concert Photography geoles2 Pentax SLR Lens Discussion 26 01-19-2014 10:29 AM
Lens for indoor photography godavari Pentax K-5 6 09-29-2011 11:14 PM
Today's Levitation - Cool Photoblog legacyb4 Photographic Technique 13 08-18-2011 01:02 PM
Macro Photography with AF Lens yusuf Photographic Technique 8 04-17-2011 06:47 PM
Favorite Lens for Night Photography Eagle_Friends Pentax SLR Lens Discussion 21 05-05-2010 12:30 PM
All times are GMT -7. The time now is 04:13 AM. | See also: NikonForums.com, part of our network of photo forums!
