04-21-2012, 09:51 AM   #1
Baard-Einar's Avatar
Lens hood for the takumar 28mm f3.5
This might be a stupid question, but I will give it a go..
I have a super-tak 28mm f3.5, and a few weeks ago, I bought a brand new-looking lens hood for this. It is the one wiht a square front. When trying to fit this on the lens, I found out that the hood does not have any threads. How do I go about fitting this hood on the lens?
04-21-2012, 10:18 AM   #2
Otis Memorial Pentaxian
Which version of the ST 28/3.5 do you have? The square hoods are designed for the later version with 49mm filter thread. I believe the hood slips on and tightens down with a ring. The early version (58mm filter thread) takes a round slip-on hood with a much larger diameter opening that tightens down with a set-screw.
04-21-2012, 12:17 PM   #3
dms
It has a clutch--rotate the ring at the back of the hood and it clamps onto the lens--that way you can mount filters inside it. But there is a 58mm and 49mm version--depending on your lens--early tak was 58mm (anyway as I recall--but it will be obvious if it's the wrong one). I think these hoods are very efficient, you just have to be aware and not bump/shift it w/o noticing it.
04-21-2012, 01:02 PM   #4
Oh! My lens is a 58mm, that explains why the square hood doesn't fit. So now, either dump the hood or the lens... hm...
Thank you for helping out.
04-21-2012, 04:24 PM   #5
Blue's Avatar
QuoteOriginally posted by Baard-Einar Quote
That means you have the early version of the 28mm!
04-21-2012, 06:47 PM   #6
dms
Actually I use the older takumar hoods on more modern lenses. I for example used this hood on a Nikon full frame film camera w/ 35mm lens and step down rings.
You just need to get a step down to 49mm and then mount a 49mm filter ring. As you have the 28mm lens and hood get a 58-49mm step down ring and then an old 49mm filter and remove the glass. I am assuming you are using dslr so the step down should be fine.
04-22-2012, 07:57 AM - 1 Like   #7
QuoteOriginally posted by dms Quote
His lens has a fairly large diameter barrel and is made to accept a 58mm filter. The hood he has is a slip-on type made to fit a lens with a much smaller diameter. A 58-49 step-down ring might physically work, but the vignette would be something awful, even on APS-C.
04-22-2012, 08:02 AM   #8
Too bad you are on another continent. I have the hood you need (pristine condition, new-old-stock, in box) sitting on the counter behind me. I bought it to fit a lens that I had to send back and now I have a hood that fits nothing in my bag. PM me if you want it and don't mind getting it from half a world away.
04-22-2012, 04:37 PM   #9
dms
(Steve) I don't know that he cannot use the hood on that lens--I for example use a hood for 135-200mm (49mm diameter) on my M 50mm f1.7 w/o vingnetting. And I use a Nikon hood for 50mm (w/ a PL or two filters) on my FA28-70mm w/o problem at 28mm.
My gut feeling is he (the OP) can! But if you have tried it please correct me.
04-22-2012, 05:00 PM - 1 Like   #10
I too use a hood designed for 50mm when shooting APS-C with my 28mm lenses. Here , the problem is not the depth of the ring + hood. The smaller hood supports the same FOV (is the same depth) as the larger model, the big difference is circumference. The large diameter 28/3.5 has a much bigger front element than the small diameter version and a 49mm step-down would actually be impinging on the edge of the glass by several millimeters. Up until a few days ago, I owned the larger version. Here is a photo so you can see what I mean...
No, that is not a filter on the front of the lens. That is the front element. Compare to ST 55/1.8 (49mm filter ring) on the same camera.
04-24-2012, 07:48 AM   #11
Blue's Avatar
+1 on Steve's posts. The earlier 28mm is a different optical design as well as having that large front element. I think both versions are over-looked Taks.
28mm, f3.5, hood, k-mount, lens, lens hood, pentax lens, slr lens, takumar 28mm
For Sale - Sold: METAL LENS HOOD takumar 3.5 28mm PentaxMom Felua Sold Items 2 08-12-2011 04:15 PM
For Sale - Sold: SMC Takumar 28mm f3.5 w/Hood and Case (US) germar Sold Items 4 10-22-2010 07:16 AM
For Sale - Sold: For Sale Super Multi Coated Takumar 28mm 1:3.5 Lens with Hood Curbster54 Sold Items 9 10-29-2008 10:01 PM
All times are GMT -7. The time now is 04:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
