04-23-2012, 08:52 AM   #1
Lens Mounts?
I purchased a box of lenses and all but these 2 were K-mounts. I'd like to see if I could use the 500mm f8 Kimunor but don't know the mount, it's obviously some interchangeable system. It's in nice shape with a preset type aperture mechanism. If you follow this link, it'll show lenses from different angles: https://picasaweb.google.com/109915535894116388289/UnknownLenses?authuser=0&feat=directlink
I have no idea what this mount is either. Looks like a decent lens, good shape but completely auto everything and it does have a macro that goes to 1:1
Thanks!
04-23-2012, 08:57 AM - 1 Like   #2
boriscleto's Avatar
The second is a Minolta/Sony A mount.
There should be a K-mount adapter for the Kimunor, good luck finding one.
https://www.pentaxforums.com/forums/sold-items/133677-sale-sold-kimunor-500mm...inolta-us.html
04-23-2012, 08:57 AM   #3
Kimunor is probably a T-mount.
04-23-2012, 09:09 AM   #4
boriscleto's Avatar
QuoteOriginally posted by Vasyl Quote
A T-mount would have male threads. Kimunor provided adapters for various mounts, including T-mount.
04-23-2012, 09:22 AM   #6
boriscleto's Avatar
No. There is nothing for the T-ring to attach to. You would need a T-adapter for the lens first, it would be better to get the K-mount adapter for the lens...if you can find one.
04-23-2012, 10:53 AM   #7
pacerr's Avatar
QuoteOriginally posted by theunartist Quote
Presuming the value of the lens is nil as it is . . .
Hold the lens up to a Pentax body and see how the registration calibration works out. Looks like the existing lens base/adapter might even offer some threaded adjustment play?
If the situation allows, you might simply epoxy a cannibalized PK bayonet mount onto the lens. With a pre-set lens you don't even loose any functionality. I have a Tamron 300/5.6 with an old Adaptall ring epoxied to it where I didn't even adjust the registry distance for infinity focus as I wanted it for a backyard close-up and bird/squirrel shooter and the slight offset simply shortened the minimum focus distance as if adding a very short extension ring.
(When I do that mod, I intentionally rotate the lens so it seats with the aperture index at 10- or 2-o'clock so I can see the aperture ring without interference from the flash hood.)
H2
k-mount, lens, lenses, mount, pentax lens, shape, slr lens
For Sale - Sold: Tamron Adaptall-2 28mm f/2.5 lens (02B); also PKA and PK mounts Nick Siebers Sold Items 6 02-27-2012 05:07 PM
Amazon 1 day lens sale - No Pentax Mounts interested_observer Pentax SLR Lens Discussion 7 12-21-2011 03:15 PM
Can You Buy Lens Mounts Rob21 Pentax SLR Lens Discussion 4 04-17-2011 06:05 PM
Help identifying lens mounts? 3ntreri Pentax SLR Lens Discussion 9 10-08-2010 10:39 PM
Distinguishing Vivitar TX vs T4 mounts when on a lens - possible? gabriel_bc Pentax SLR Lens Discussion 4 07-29-2010 05:35 AM
All times are GMT -7. The time now is 05:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
