04-23-2012, 03:51 PM   #1
junototoro's Avatar
Questions about DA* 55mm f/1.4 SDM
I'm an absolute beginner of DSLR. I own a k-r and recently got the 55mm 1.4 lens from B&H. I probably dont know how to use it at all and have a few questions:
1) when I move the camera after auto focusing (pressing half down), the focus changes. This doesn't happen with the 18-55mm kit lens. Is it normal?
2) when the subject of the shooting moves, the focus also shifts.
Am I doing something wrong or is this lens supposed to be only used for non moving objects?
Thanks. Would appreciate if anyone could give me some basic tutorial on this. If I need to test it thoroughly can someone tell me how to test it please? Thanks in advance.
04-23-2012, 04:02 PM   #2
axl
One question for you:
Are you sure you don't have camera in AF-C mode?
There is no reason any lens should/would re-focus in AF-S mode regardless of whether you or the object move or not or whether.
my 2p
04-23-2012, 04:09 PM   #3
junototoro's Avatar
It was on AF.A...
04-23-2012, 04:15 PM   #4
junototoro's Avatar
It worked fine with AF.A when I use the kit 18-55mm lens
I think I'll choose AF.S for the 55mm 1.4 lens! Thanks!
04-23-2012, 04:33 PM   #5
hcc
hcc's Avatar
QuoteOriginally posted by junototoro Quote
It worked fine with AF.A when I use the kit 18-55mm lens. I think I'll choose AF.S for the 55mm 1.4 lens! Thanks!
For non moving object, you are better setting AF.S. AF.C is primarily for fast moving objects and it is less accurate IMHO.
Hope that the comment may help.
04-23-2012, 04:35 PM   #6
junototoro's Avatar
Hmm, I thought it was the other way around?
Difference between AF-A AF-S AF-C focus settings Nikon focus modes
04-23-2012, 05:39 PM   #7
QuoteOriginally posted by hcc Quote
For non moving object, you are better setting AF.C. AF.S is primarily for fast moving objects and it is less accurate IMHO.
The other way around The C in AF-C is for continuous.
04-23-2012, 09:39 PM   #8
hcc
hcc's Avatar
QuoteOriginally posted by Eberbachl Quote
Correct. mea culpa. Just edited the post.
04-24-2012, 03:15 AM   #9
junototoro's Avatar
By the way, how fast is a fast object? Sports? Concerts/Dancing? Bird flying? Do you use AF.C then?
04-24-2012, 03:52 AM   #10
axl
anything that moves is better done with AF-C if you want the camera to track the subject,
static objects are better off with AF-S (single)
I suspect the AF-A to be culprit here because of the thin DOF caused by fast lens.
04-24-2012, 08:52 AM   #11
maxfield_photo's Avatar
Imagine a sheet of paper held parallel to the front element of the lens, that's about how much DoF you have at 1.4. So yeah, the DA*55 when shot wide open is best for portraits or maybe product shots. Try shooting at f/8 and maybe bump the ISO up a bit to get the shutter speed you need. TAv mode is great for that.
Another thing you can do, though it takes some getting used to, is take the AF function off the shutter button, and move it strictly to the AF button. In AF-C mode as long as you hold the AF button the lens will focus, when you release it, it will lock, and pressing the shutter button will not cause it to change focus. That's what I have mine set to, and I love it now, but I missed a lot of shots while getting used to shooting that way.
55mm, da* 55mm f/1.4, focus, k-mount, lens, pentax lens, questions, questions about da*, slr lens, test, thanks
For Sale - Sold: Pentax DA 55mm f1.4 SDM Lens Marcus Kauffman Sold Items 5 04-19-2012 06:35 AM
DFA 645 f2.8 55mm AL[IF] SDM AW not usable with K5/K7 ?!? Wololo Pentax Medium Format 9 09-17-2010 04:23 AM
New 55mm SDM 645D lens means no SDM II? alehel Pentax News and Rumors 11 03-14-2010 09:43 AM
SDM questions Waheed_Sadaf Pentax SLR Lens Discussion 17 11-23-2009 04:53 PM
All times are GMT -7. The time now is 06:38 PM. | See also: NikonForums.com, part of our network of photo forums!
