04-23-2012, 07:10 PM   #1
Pentax-K SMC 50mm 1:1.4
I have just purchased this P/K lens on fleabay with a serial number of 1099154.
Reviews I have looked at tells me that this is the sharpest lens Pentax has ever made.
What are fellow Pentaxians thoughts on this type of lens?
Thanks,
MR.
04-23-2012, 07:23 PM   #2
Probably not the sharpest ever, but it's pretty darn good, especially considering its low price.
04-23-2012, 08:38 PM   #3
Also the bokeh you can get with this lens is wonderful. I have one...I love it.
04-23-2012, 09:11 PM   #4
Swift1's Avatar
I would say, maybe one of the sharper 50/1.4s from Pentax, but not the sharpest lens ever. Maybe you were reading about the K 50/4 Macro.
I have found the K 50/1.4 to be a lot like the SMC Takumar 50/1.4, both have very similar rendering and bokeh.
04-23-2012, 09:20 PM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by Swift1 Quote
....funny thing...
(...same lens, different barrel...)
04-23-2012, 09:22 PM   #6
Swift1's Avatar
....funny thing...
I figured that, but wasn't certain.
04-23-2012, 09:26 PM   #7
Yeah, the 50/1.4 did not change much through its history. Ditto for the 55/1.8. Why mess with a good thing?
04-23-2012, 09:32 PM   #8
Swift1's Avatar
I seem to remember reading that the M version was slightly different?
I had an M a few years back and didn't really like it much but that may have been partly cause I didn't really know what I was doing.
I also had a SMC Tak version that I sold last year but before I sold it I found the K version.
04-23-2012, 11:17 PM   #9
You may find this lens shootout interesting, as it tests out both the A50/1.4 and M50/4 Macro:
Nifty 50 Shootout : ERPhotoReview
We can probably assume that the various flavours of these lenses are optically very similar, if not identical. You'll notice that the Macro is by far the sharpest wide open, but wide open means f4, of course. If you stop the 50/1.4 down to f4, it's pretty much on a par with the Macro, also at f5.6, perhaps less so at f8.
I think that's an impressive result, especially when you consider that you get nearly as much resolution at f2.8. The results also imply that the 50/1.4 is relatively soft at f1.4, so that's worth bearing in mind when looking at your results with this lens.
04-24-2012, 03:42 AM   #10
macTak's Avatar
Yes, the optical design did change a bit (although it remained a 7/6 construction) from K (which was the same as the SMC Tak) to M, and then it changed again from M to A (again, still 7/6).
04-24-2012, 06:39 AM   #11
gofour3's Avatar
Yep the K50/4 macro is the sharpest K series lens. The other standard 50-55mm K series lenses are about the same, depending on the aperture used.
Phil.
k-mount, lens, pentax lens, pentax-k smc 50mm, slr lens
For Sale - Sold: Pentax SMC-M 28mm F2.8 and Pentax SMC-A 50mm F1.7 (non func A setting) (US) pxpaulx Sold Items 5 07-23-2010 10:38 PM
For Sale - Sold: SMC Pentax-F 35-70mm F3.5-4.5;SMC Pentax-A 50mm F2;SMC Pentax-DA L 18-55mm F3. TATA Sold Items 14 06-17-2010 04:05 PM
All times are GMT -7. The time now is 01:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
