04-23-2012, 07:26 PM   #1
hagiri_11's Avatar
Used FA 43mm lens barrel wobble - is it normal?
I managed to get a used FA 43mm from ebay recently, but I noticed that the lens barrel and aperture ring does wobble quite a bit.
Is it normal?
I've tried shaking the lens a bit, and nothing seems to sound loose inside. Also, everything looks tightly screwed, nothing looks loose on the outside. It also performs well, AF is good and doesn't seem to have any problems with the IQ.
04-23-2012, 07:50 PM   #2
creampuff's Avatar
I've owned 2 copies of this lens. It should not wobble at all.
04-23-2012, 08:06 PM   #3
twitch's Avatar
Doesn't sound good to me. At the very least I'd get it fixed as a bad wobble could mean it will fall apart eventually.
04-23-2012, 08:09 PM   #4
hagiri_11's Avatar
Maybe 'wobble' would be exaggerating - it's more of a rattle.
Can it be just that the lens barrel has a little bit of play? Because it only rattles a bit if I hold the hood and move it around.
04-23-2012, 08:44 PM   #5
QuoteOriginally posted by hagiri_11 Quote
FA43 and FA77 have similar constructions and both should be solid and tightly constructed.
04-23-2012, 09:07 PM   #6
Sol Invictus's Avatar
Mine has the slightest bit of rattle too. Not enough to be concerned with for me.
04-23-2012, 09:53 PM   #7
mikeSF's Avatar
i have the slightest play in the aperture ring. lens barrel has no play whatsoever. focus ring makes the usual faint chatter of gears(bearings) when turning, no rattle of any sort.
i would be concerned based on what you describe. good luck.
04-25-2012, 09:57 AM   #8
ironlionzion's Avatar
Your guys' 43mm doesn't wobble even just slightly? Mine wobbles maybe 1/50th of a mm (purely an estimate), and I can hear it if I put my ear up to it. I can't imagine this having any effect on IQ, but I guess if it gets worse I should get it checked out.
43mm, barrel, bit, fa, k-mount, lens, pentax lens, slr lens
Pentax SMC-M 50mm f1.4 lens barrel wobble Dan Chang Pentax SLR Lens Discussion 8 12-30-2011 10:22 AM
Recondition the plastic on the lens barrel Gareth.Ig Pentax SLR Lens Discussion 7 05-30-2011 05:31 PM
Moisture on lens barrel Schraubstock Pentax SLR Lens Discussion 8 11-28-2010 03:27 PM
Does DA70 barrel wobble? selar Pentax SLR Lens Discussion 2 03-12-2008 05:40 AM
Zoom lens wobble, should I not tolerate it at all? gawan Pentax SLR Lens Discussion 10 02-07-2008 11:10 PM
All times are GMT -7. The time now is 05:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
