05-03-2012, 01:22 PM   #16
Lloydy's Avatar
QuoteOriginally posted by Vasyl Quote
by the way...you can use break liquid from your car it is:
a) a good solvent
b) perfect penetrator through the cracks...
Just use a pipette to put a couple of drops around the ring and put it upside down (front element down) for the liquid penetration.
Good luck!
Brake fluid is highly corrosive and a very effective paint stripper. I would not put it on any part of a lens under any circumstances. But your mileage may vary ?
05-04-2012, 08:14 AM   #17
QuoteOriginally posted by Lloydy Quote
That is why it is in touch with rubber materials and plastics in your car...
It is a good SOLVENT but not a CORROSIVE liquid...it is a mixture of organic substances there is nothing in there what may trigger corrosion.
Agree that it must be kept away from contact with lens, because it will destroy the coating.
05-12-2012, 02:43 PM   #18
Jean Poitiers's Avatar
08-15-2013, 04:49 PM   #19
Hi. Got the same lens with the same problem - fungus. Started disassembling. Got stuck at the shade part. Removed stopper screw from shade base, but can not remove it. Could you elaborate how you got pass that stage. Thank you.
Canon EOS Kiss X4  Photo
08-16-2013, 09:39 AM   #20
If I remember right you, and looking at your picture, I think you only have to turn it counter clockwise as it's probably simply screwed in.
Look at my first picture. Right under the the front element's ring, there you will see the peripheral threads on which the hood/shade screw.
Let me know how it goes.
08-16-2013, 09:40 AM   #21
Did you remove the front ring at all?
08-16-2013, 01:43 PM   #22
Hi, thanks for the quick reply. Yes I have removed the front ring. I was afraid to use force unscrewing it, but from what you say it is a matter of applying some force and unscrewing. Will try it tomorrow hen I get home. Thanks again.
08-17-2013, 07:27 AM   #23
Tried to unscrew. No effect. It stuck like cement.
135mm, auto, couple, element, front, glue, k-mount, lens, pentax lens, slr lens
[SOLD]Auto Chinon (Revuenon/Tomioka) 55mm f/1.7 m42 lens dcshooter Sold Items 6 03-29-2012 03:51 PM
For Sale - Sold: M42 Super Taks 50/1.4, 135.3.5, Auto Chinon 28/2.8, M42 adapter,Sun 2x tele converter olivemike Sold Items 3 12-18-2011 04:18 PM
Chinon 135mm f2.8 M42 BeerBelly Troubleshooting and Beginner Help 4 02-03-2011 11:54 PM
All times are GMT -7. The time now is 04:27 AM. | See also: NikonForums.com, part of our network of photo forums!
